code 3 how to fix?
Old Mar 14, 2003 | 03:17 PM
importboi22's Avatar
Hks Ownz Me (
code 3 how to fix?
i got a code the something about the crank angle sensor ( g sensor) how would i go about fixing this? thanks
josh
Old Mar 14, 2003 | 03:31 PM
HAILERS's Avatar
HAILERS
The G signal is the rotor position signal. Ring out the two coils on the cas from the ECU plug. See the fsm for pin numbers. Probably a loose connection at the cas or ECU. Or someone has been fiddle frickin with the inside of the cas.
Old Mar 14, 2003 | 08:12 PM
RETed's Avatar
It sounds to be a notorious problem for Kouki cars.&nbsp I helped another member "fix" this problem with a CAS swap, but it turned out to be a bad connection.&nbsp I'm working on a Kouki vert right now that spits out that same code.
Pull connector and try and see if you can clean all contacts.&nbsp Push connectors together HARD to make sure proper contact.&nbsp The mag sensors rarely fail themselves.
-Ted
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
musker
Oct 1, 2015 05:58 PM
