Fuel in the oil???
Old Mar 14, 2003 | 10:20 AM
rotorboy's Avatar
Fuel in the oil???
Has anyone ever heard of this and what causes it. I checked the oil the other day and it smelled like fuel. The next day I changed it, and it was really thin and smelled strong of fuel. What causes this? Thanks for any information. 87 TII
Old Mar 14, 2003 | 10:38 AM
hIGGI's Avatar
Hey James
Our friend does have same problem, we have not found anything whats causing it yet Fuel must be somehow leaking into oil system, but its internal leak - no leaks outside )
Old Mar 14, 2003 | 10:43 AM
Turbonut's Avatar
Here's some reading. You will always experience some contamination from the gas. Just keep up with the oil changes.
https://www.rx7club.com/forum/showth...hreadid=123082
Old Mar 14, 2003 | 11:04 AM
hIGGI's Avatar
I am talking about HUGE contamination (he had in more FUEL than OIL)
Old Mar 14, 2003 | 11:11 AM
NOS FC3S's Avatar
Could be a leaky injector?
I now its common on piston motors. Not sure if rotary has the same symptoms.
Old Mar 14, 2003 | 11:16 AM
Hey I have the same things on my 90 TII but don't know what is causing it, nut I do know the longer you take between oil change the stronger it gets.
Old Mar 14, 2003 | 11:19 AM
Turbonut's Avatar
Well, the only way fuel is going to get into the oil is via injectors, unless someone poured it into the engine. He should have experienced a problem, eg flooding, drop in fuel mileage etc. Extended oil change, even possibly overly rich conditions on cold starts.
How about more info and maybe the guys can help.
Old Mar 14, 2003 | 01:09 PM
RETed's Avatar
Consistent flooding and/or worn oil control o-rings will cause this problem.&nbsp Also, incorrect porting will cause excessive blow-by.
-Ted
Old Mar 14, 2003 | 01:35 PM
JDMkamikazeeRX's Avatar
How many miles does you car have? It could most likely be an old engine with low compression.
Old Mar 14, 2003 | 02:11 PM
fastrotaries's Avatar
W. TX chirpin Monkey
it's excessive flooding or Oil control rings going south. They are design to keep the thicker oil out of the combustion chamber, not excessive amounts of gas from getting to the oil.
The1Sun
Mar 18, 2018 11:08 PM
Snoopy FD
Dec 8, 2015 01:45 PM
