Injector is leaking bad help.
Old Mar 13, 2003 | 04:38 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Ok on of my secondaries is leaking really bad so I can't drive my car. What parts would I need to order from Mazdatrix? I have an idea but I am not sure.
Old Mar 13, 2003 | 04:39 PM
1987RX7guy's Avatar
I think I need the injector grommets. I would have to buy the top and bottom grommet right?
http://mazdatrix.com/c-6.htm
the grommets are on this page.
Old Mar 13, 2003 | 04:46 PM
dr0x's Avatar
pei > caek
The grommets should stop it unless there is damage to the fuel rail some how (causing the leak).
Old Mar 13, 2003 | 04:49 PM
kep0ne's Avatar
you need top, bottom, and the o-rings.
Old Mar 13, 2003 | 04:56 PM
1987RX7guy's Avatar
ok thank you.
Old Mar 13, 2003 | 04:58 PM
Fitness Stain's Avatar
Yar-Har-Har
i would suggest just sending them off to Rc engineering so they can be clean...if your gonna have them off anyway...that way you know that none of them will fail anytime soon...its only like 20 bucks per injector which is a small price to pay for a sound mind
Old Mar 13, 2003 | 04:59 PM
That's only partly true. There could also be splits or cracks in the injectors from excessive wear. So once you have the injectors out of the car, go over them with a magnifine glass if you have too. The entire injector might need replacing. I guess you'll find out soon.
Old Mar 13, 2003 | 05:00 PM
1987RX7guy's Avatar
ok i will check them out thanks for the replies.
Old Mar 13, 2003 | 05:24 PM
Ok--I have what I think is a similar prob....86 NA with no mods and 87K original....I was driving and it just cut out on me, and that was the last time it fired up....when I first got it home and checked compression, there was NONE, and I took this to mean that it was really flooded. Got the extra gas out of the engine, and tried a little ATF....it would almost start, but stall right out immediately.After I got the gas out, it had compression, but it just doesn't want to start. Am I on the right track in thinking that I have an injector leak? I planned to have them cleaned anyway, but I want to make sure I am not looking in the wrong place. Where is Rc Engineering anyway? I know there are lots of things in the archives about flooding, but I just want to make sure I shouldnt be looking at something else....
Old Mar 13, 2003 | 06:30 PM
Yar-Har-Har
search them up in google..
you'll find them
they fixed my **** in a hurry and havent smelled gas since.....except the taco bell kind!
Old Mar 13, 2003 | 07:10 PM
you'll find them
Too much info!
Old Mar 13, 2003 | 08:27 PM
J-Rat's Avatar
Alcohol Fueled!
The grommets are also available from the local parts stores. At least the ones around here seem to have them.
Jarrett
Old Mar 13, 2003 | 08:33 PM
1987RX7guy's Avatar
Ok i have four spare injectors from an 88 GXL
the diferent injectors have this number on them. 195500-1350 but on the GXL's injectors it says denso on the sport's it says"23" on the other side. Can i tell if they are compatible like this or do I have to check out the VIN#'s
Old Mar 13, 2003 | 08:44 PM
1987RX7guy's Avatar
Ok i went out and checked the vins and they are not compatible. Just out of curiosity what would happen if i put the 88 injectors in the 87?
Old Mar 13, 2003 | 09:38 PM
1987RX7guy's Avatar
she is alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
I used the other o-ring and grommets and no more leak. Yes I ran her and she feels a little faster than before. I guess the port cleaning was a good idea after all. Now i just have to trouble shoot my exhaust leak but that is easy ****. Thank you all. MAN I LOVE MY CAR!
Old Mar 13, 2003 | 11:38 PM
Good stuff man! I love my car too!
Old Mar 14, 2003 | 08:28 AM
Cory Simpson's Avatar
I wanta be with the BUC!
Well for the question you asked on the other thread to get the pintle cap off you can either grease it up with WD40 or somthing of that nature and then try to pull it off by putting a thin rag around it and grabbing it with a pair of plyers and pulling and hope that it doesn't break. Or you can just score it with a knife and buy new ones from mazdatrix thats what I did I brike them all trying to get them off so I had to. Or you can just run them when they are broke it shouldn't hurt anything all they are there for is to hold the rubber spacer in one place I believe.
Queppa
Nov 18, 2024 03:47 AM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
