would these intakes work????
Old Mar 11, 2003 | 10:57 PM
adssoccer's Avatar
Question would these intakes work????
ive got a 84 gsl-se, and i know theres a way to get a cone intake on there using an adapter plate. would an adapter plate built for an 86- work? i see these on ebay. . . would they work?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
or
Old Mar 11, 2003 | 11:28 PM
RacerX7fb's Avatar
paradox
The intake will work but as it states, the adaptor plate is made for the 86-92 RX-7. They have a larger sized AFM. There are adaptor plates available that will fit the GSL-SE or have one custom made for you.
Old Mar 12, 2003 | 08:10 PM
adssoccer's Avatar
ok, i did a search, and if all the other posts are correct, the 86-91 adapter plates should fit right on to the gsl-se intake. right? those plates on ebay look exactly like the hks adapter plate k2rd.com used to sell. but k2rd sold them at $25 or $30, and these are for $6.
but back to my original question, is that correct that the 86-92 adapter plate will work just fine on my gsl-se in setting up for a cone filter? if not, where can i get one for a gsl-se besides having one custom made? or does anyone know how to make a homemade adapter plate? i remember seeing a site that showed how, but i can't find it now. thanks
Old Mar 12, 2003 | 08:15 PM
JIMMY54's Avatar
GSL-SE PRO
I use the HKS one for the 2nd gens. It worked great, and i had no problems with it at all.
Old Mar 12, 2003 | 08:28 PM
heh I went to home depot, got one of those alluminum gutter pieces that lets you have a down pipe drain, cut off the sides and bolted the bottom downspout piece on, then bolted the filter to the piece. worked great and cost like 5 bucks
immanuel__7
89
Sep 5, 2015 10:23 AM
