'73 Carb Adjustment
Old Mar 10, 2003 | 03:15 PM
Re-Speed.com's Avatar
'73 Carb Adjustment
Ok guys.... I used to remember this stuff.
I have a 73 carb that has the two mixture screws. These are on the base of the carb. Standing on drivers side looking across the motor at the carb there is an upper and lower one. Upper is big the lower is smaller.
If not mistaken once emissions came into play the lower one was capped so you could not mess with it.
I seem to remember a good starting point after a carb rebuild was to screw them all the way in and back them out a curtain number of turns. Any one got an idea?
-billy
Old Mar 11, 2003 | 12:21 AM
Darth Linux's Avatar
2 1/2 turns for each is the baseline from the FSM I have.
good luck!
Old Mar 11, 2003 | 09:35 AM
Siraniko's Avatar
RX for fun
if not mistaken, the big button is the air while the small one is for fuel.
Old Mar 14, 2003 | 07:15 AM
R Lee's Avatar
use the big one first for air and small one for idle.
