The Twin Turbo Blues!
Old Mar 9, 2003 | 04:36 PM
JAMMNN's Avatar
I can only get a 8-5-8 boost pattern. I have tried everything I can think of.
I am attempting my second hose job now.. with all new silicone hose. I was wondering if a cracked manifold would cause this? I have the Y-pipe, Apexi FMIC, and Apexi Power FC, I also have had my turbos rebuilt.
The other thing I was wondering was when I reinstalled the turbos. I was able to turn the housings. Is this normal? I am assuming it is, so you can align the outlets.
Any Ideas?
Thanks.
JM.
Old Mar 9, 2003 | 05:08 PM
xstacy7's Avatar
I love when things work
turn the housings??? never heard of that one before, you can turn the y-pipe to align the outlets...might want to get that one checked out
Old Mar 9, 2003 | 05:53 PM
poss's Avatar
Slower Traffic Keep Right
turning the housings is called "clocking" and it is possible with stock turbos. you did tighten them up right?
sounds like a boost leak to me, since you are getting the same pressure before and after the transition.
Old Mar 9, 2003 | 11:44 PM
duboisr's Avatar
the turbo center section and cold side needs to be clocked in .The center sections gets tightened with 6 bolts each ebsure they are tight, the cold side has a big snap ring if loose will let you clock ti in position. Be sure the ring is seated in its grove.
Old Mar 12, 2003 | 05:14 PM
JAMMNN's Avatar
Explain clocked in? The side with the snap ring did not totally lock in place but the ring is in its groove. I figured that the rest of the secure points would keep it in place. Would this affect the boost?
streetlegal?
Mar 17, 2022 02:46 PM
