What happens on a T2 between 2500-3000rpm?
Old Aug 20, 2001 | 01:07 AM
ROSHX7's Avatar
Question What happens on a T2 between 2500-3000rpm?
Eh guys, right now on my 87 TII, I get some sort of hesitation/bog at somewhere between 2500-3000rpm on light throttle. I was wondering what could be happening at those RPMs?...does the car switch something ON or anything happening with the TURBO at that point?
Old Aug 20, 2001 | 01:34 AM
RedRacinTII's Avatar
Check your throttle position sensor.Do a search on here and you will find lots of stuff.I personally have written quite a few things about it.That is more than likely your problem, but there is a chance it's something else.
Old Aug 20, 2001 | 02:47 PM
Last night I realized that most of the posts regarding the TPS were probably lost when the system crashed.If you need more info on it let me know.
Ryan
Old Aug 20, 2001 | 02:54 PM
cymfc3s's Avatar
I Raise Chickens
at 3,200 the secondaries come on.
Old Aug 21, 2001 | 12:20 AM
Henrik's Avatar
At 2600rpm the flapper on the twin scroll moves, can't remember which way though. You can test it at idle, with the car off, mark the actuator rod with white out or something (its the stainless steel one right at the bottom, might be hard to see if you have ABS), start the car and the mark should disappear (vacuum applied to actuator) rev past 2600 and it should come back.
Henrik
87TII
Old Aug 21, 2001 | 01:10 AM
HWO's Avatar
HWO
inteligent extratarestril
could have sworn the come on whenever there was +ve manifold pressure or 3200rpm which ever came first, anyway, between 2500 and 3000 rpm the stock ecu is showing how useless it really is.
upgrade to a tuneable efi system, you'll never look back
msilvia
28
Apr 14, 2016 12:58 PM
Crazyw0lf
Feb 21, 2015 12:19 PM
jaggermouth
Aug 11, 2012 02:02 PM
Zero10
11
Jun 5, 2012 12:53 PM
FC3Sdrift
19
Jun 2, 2010 02:48 AM
