who has the rx6b?
who has the rx6b?
Im just curious as to how you can tell the two apart, is it clearly marked rx6b? and what type of numbers do these put up? do these bolt onto the normal rx6 manifold?
Trending Topics
Hmm... it sounds like you can keep the air pump with the later A kits, too. For those that can keep the air pump, is your turbo in a different place than mine, shown here?:
More pics here.
I haven't tried it, but I am quite sure that mine would not fit with the air pump. The runners on my exhaust manifold are about a foot long, and they swoop up and forward a bit from the exhaust ports. I saw a pic of another manifold from A'PEXi that was shorter and didn't swoop up as much.
apexkw, it seems like the ability to keep the air pump or not in not an indicator of which turbo is in the kit. The RX6A/RX6B just refers to the turbo itself as far as I know. There may be other differences in the manifold and/or maybe the downpipe, too, but I am not sure.
-Max
More pics here.
-Max
i have the original kit. there is no way the airpump would fit. my airfilter also goes in a totally different spot. it sits in most of the space that the airpump occupied. my filter is almost touching the coolant housing. and my intercooler pipes run along the left side of your intake cone.
Info on RX-6B
Here is the part number for the rx-6b
rx-6b oil cooled: 702-Z720
rx-6b water cooled: 702-Z730
The larger one you are talking about is the AX kit.
The rx-6b lets you keep the air pump in the Jspec car. On the US spec car, the filter hits the A/C line. It only fits the air pump if you change the intake pipe or take out the A/C line.
I have compared part numbers from the US apex price guide and the Japanese apex price guide to come to this conclusion.
Chuck Huang
Chuck Huang
Hey Chuck, correct me if I am wrong, but I thought there were only two differences in the RX6a/RX6b. One was in the exhaust manifold. The b manifold is different allowing it to sit lower off of the engine so the stock airpump can still be retained. The turbos themselves though are identical. Secondly, an upgraded wastegate given the A model having a poorly designed valveguide.
Kevin
Kevin
I called apexi usa today and a long talk with them, I had them check out my turbine serial number and it came back as the rx6b, with the .p27 tcw77ls which according to them will flow 550hp as opposed to the rx6a which flows 450hp. Just figured Id let you guys know. He said that this is the biggest they make right now.
apex, apexi, boost, controller, fc, fuel, integration, knob, mazdaspeed, pressure, regulator, rx6b, rx7, shift, tcw76
mine i cant find my number lol
