Ideas on how to fix tirewell holes.
Old Mar 6, 2003 | 07:46 PM
exodus82's Avatar
IM NUMBER ONE TWICE TODAY
SHEETMETAL AND BONDO
Old Mar 6, 2003 | 07:48 PM
What the hell, i posted something and it didn't post it... Went back to post an actually message, and it did the same damn thing..... Well anyways.
I have rust holes in the tire wells of my SE. On my GSL i used a combination of steel plates and fiber glass to remedy the problem. Is there a better way to go about this?
Billy
Old Mar 6, 2003 | 07:54 PM
White84SE's Avatar
U sUx0rz @ THe IntaRwEB!
Cutting out the old and welding in new is the only intelligent way to fix this. Fiberglass, bondo, all that crap is not only a temporary patch that WILL come back to haunt you, it's also a safety risk. These cars are unibody and rely on the strength of all the steel in the bodyshell to support it. Make a small square of 3/4" inch think bondo and hit it with a hammer. Do the same with a 1/4" thick sheet of steel. There's your answer...
--Danny
Old Mar 6, 2003 | 08:11 PM
The only problem is the design of the metal back there. The outer and inner sheets don't rust, but the inside goes to hell. I would end up cutting out most if not all of the tirewell, and i can't weld for ****... But i don't want a temporary fix... man, im screwed....
Old Mar 6, 2003 | 09:13 PM
mwpayne's Avatar
Admitted 'rexaholic'
Body shop should be able to do it for $100-$200.
Worked for me!
Old Mar 6, 2003 | 09:18 PM
White84SE's Avatar
Yes.. if you can't do it yourself, find a competent bodyshop who can do it. Look around and make sure they actually have a welder though, as I've seen quite a few patch jobs done that are quickly painted over and look like metal for about 6 months. Then the bodno cracks and wrinkles and, surprise the rust is back and even worse. If you do take it to a bodyshop, ask to see it after it's welded, but before they paint over it.. just in case.. and take a magnet along, too..
rgordon1979
40
Mar 15, 2022 12:04 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
meetRoX7e
Sep 11, 2015 11:09 AM
