Custom 20B intake manifold!!!
Old Mar 4, 2003 | 01:42 AM
crispeed's Avatar
'Tuna'
Check out the pics of the custom 20B intake manifold on hogansracingmanifolds.com
It's in the products section.
crispeed
87 Rx-7 TII
9.204@150.47mph
2600lbs
un-tubbed
Old Mar 4, 2003 | 02:47 AM
AJC13B's Avatar
10.32 @ 133
Old Mar 4, 2003 | 03:51 AM
88fc3sw/HX83's Avatar
Why doesnt someone make one for the 13b? If there is one, Ill buy it NOW!
Old Mar 4, 2003 | 04:29 AM
680RWHP12A's Avatar
i wonder who owns that manifold???
they made my 12a manifold.....$1,900 later ,,,im very sore!!! p/s customer service is non-existant!!!
nice product , made more power!
Old Mar 4, 2003 | 08:04 AM
relvinnian's Avatar
Hogan will make you an intake manifold for your turbocharged lawnmower if you want them to! It'll be efficient as hell too! LOL
Old Mar 4, 2003 | 09:06 AM
DELTA_Rotary's Avatar
Bourbon King
Oh shiney...
Old Mar 4, 2003 | 11:19 AM
black99's Avatar
Lurking..................
I can only guess the price tag of that thing..
Old Mar 4, 2003 | 11:55 AM
RX-Heven's Avatar
I'll blow it up real good
$3200 for that thing. Of course they custom make each one to your own specs. I'm waiting to see if MVA's is any cheaper/better.
Old Mar 4, 2003 | 03:34 PM
AJC13B's Avatar
10.32 @ 133
Whats up with the square turns? That can't be good for air flow!?
Old Mar 4, 2003 | 09:38 PM
89S13's Avatar
AJC13B
Since you are from Australia you might not be aware of the great reputation that Hogan Manifolds have. They are used by the top tuners in the performance industry in the US. Trust me they know what the're doing.
Old Mar 4, 2003 | 11:06 PM
Jesuscookies's Avatar
I can haz rotary?
That is a bundle of cash, for a manifold!!! Some of the tuner shops in australia have some pretty nice looking manifolds for about an 1/8 of the price.
Old Mar 5, 2003 | 12:46 AM
RX-Heven's Avatar
Have you seen any that offer a 20b manifold?
Old Mar 5, 2003 | 02:36 AM
PPC-Racing's Avatar
pretty manifold , but I think the same thing with better flow could be made allot cheaper with pre cast, high quality aluminum elbows and laser cut flanges..even mandrel bent 16 Ga, 6061 mandreal bent 1 1/2" would be better pricing then $3200 WOW.
I'd like to know why they chose to make it CnC instead of mandrel or cast tube? seems to me they could make allot mor money, open up the flow and still reduce the cost..
Old Mar 5, 2003 | 03:28 AM
AJC13B's Avatar
10.32 @ 133
No one has them off the shelf, but most places will make one up for you and it will cost less than $2000AUD, let alone anywhere NEAR $3200USD!!
Old Mar 5, 2003 | 07:26 PM
why is one of the primary runners enlarged?
Old Mar 5, 2003 | 07:56 PM
Red-Rx7's Avatar
Administrative Me
Its not just one... its the design.
(left to right on the UIM piece, which mates to the LIM piece)
Big + Little = 1st rotor
Litte + Big = 2nd rotor
Little + Big = 3rd rotor
Mike
Old Mar 5, 2003 | 09:50 PM
Bourbon King
Originally posted by 89S13
AJC13B
Im not sure Ive ever seen them on any of the big HP cars? Could you rattle off a few names that use them?
Old Mar 6, 2003 | 06:24 AM
banzaitoyota's Avatar
What Subscription?
Jimlabs LS1 has one
Old Mar 6, 2003 | 07:25 AM
No7Yet's Avatar
I should note that until a few days ago, Jim also owned the highest N/A horsepower LT1 at 647 hp (he was beat out by two hp).
To say that the manifold had nothing to do with it would be idiocy. I'd say that the manifold is 90% of N/A power!
Brandon
Old Mar 6, 2003 | 09:22 AM
What Subscription?
And that hp was produced with a flakey front cover(which affected timiing) JIMLAB will return to the TOP!!!!!
Old Mar 6, 2003 | 02:39 PM
jimlab's Avatar
Super Snuggles
Keep in mind (as banzaitoyota pointed out) that my 647 horsepower pull was on the base maps, prior to tuning, and with a huge ignition-caused dip through the peak power zone. The other engine's numbers were after final tuning.
My engine will probably make 660-665 horsepower with just the ignition fix, and possibly more after final tuning.
Actually, although the manifold certainly helps, cylinder heads are the key to NA power. Hard to say what percentage of my power is solely attributable to the intake, since I can't swap a stock LT1/LT4 intake onto my engine for comparison. I'd guess that there's probably 15-20 horsepower that are attributable to the intake alone, but the rest is solely a function of my heads and cam. I spent more than twice what my intake cost on my heads.
BTW, Hogan's was not all that happy with the height requirements of the intake and wanted the runners longer with a larger plenum volume. I suspect that if I'd let them have their way that we'd probably have a few more horsepower to show for it, but my intake was purposely built 1/2" shorter than a stock LT1 intake for even more hood clearance. The process took awhile, but was well worth it, in my opinion. The alternative was to run an EFI converted Edelbrock Victor Jr. intake with a throttle body. It would have been cheaper, but probably wouldn't have performed as well and definitely wouldn't have fit beneath the stock hood.
Hogan's builds intakes for many professional drag racers (Wilson's is another big name in the industry where custom intakes are concerned). There is a lot of power to be found in intake designs. So much so that many Pro Stock cars (arguably the most competitive class in NHRA drag racing) actually guard their intake designs by taping cardboard panels over them to hide the details. When a field of 20 cars can qualify within several tenths of a second of each other, every little advantage counts.
Hogan's doesn't just build intakes that look pretty. They're very purposeful, and performance is the first priority. Not how it looks, or whether they could save a buck by using cast aluminum parts or mandrel bent tubes. If you're paying for a Hogan's intake, you know that you're getting the best intake that money can buy, because they will have fully analyzed the flow characteristics of the design before building it instead of just slapping something together that "looked good". I guess it depends on whether getting every last horsepower out of your engine is important to you.
Old Mar 6, 2003 | 04:01 PM
AJC13B's Avatar
10.32 @ 133
Sure sure Jim, V8 owners always have an excuse
Old Mar 6, 2003 | 04:48 PM
jimlab's Avatar
Super Snuggles
Old Mar 6, 2003 | 08:32 PM
Cheers!'s Avatar
Former Rx7 *****
jim can i get a ride in your car?
Old Mar 7, 2003 | 09:12 AM
rotarygod's Avatar
Rotors still spinning
Hey Jim you got a website showing that LT-1 beast?! I'd like to see that!
