coolant leak HELP
Old Mar 3, 2003 | 11:34 AM
masterrigger's Avatar
coolant leak HELP
i have coolant sitting on the top of the engine where the intake bolts up. it is not the thermostate housing. what else could it be? does coolant run through the intake manifold?
Old Mar 3, 2003 | 11:40 AM
pillage6's Avatar
Yes it does, replace the intake gasket.
Drain the coolant first though.
Old Mar 3, 2003 | 11:42 AM
great i was hopping it did THANKS
Old Mar 3, 2003 | 12:09 PM
mar3's Avatar
Administrator
Probably one of the "O" rings gave out....
Old Mar 3, 2003 | 01:31 PM
RotorMotorDriver's Avatar
Seven Is Coming
Yeah, what they all said . mazdaTrix can sell you the two O rings you need .
~T.J.
PS - I think this is what you need, but you might wanna double check that:
http://www.mazdatrix.com/getprice.as...m=13-1130-8527
Old Mar 3, 2003 | 02:00 PM
exodus82's Avatar
I got my o rings from the mazda dealer
really cheap i think they were like $5 CND
Coolant is a bitch to not let get all over the place. There isn't a drain plug so you have to disconnect a hose if i remember correctly
Old Mar 3, 2003 | 03:48 PM
cheapie's Avatar
Yup. I replaced the intake gasket and got coolant all over the place including inside the engine. what a mess. Then I realized that I needed new radiator hoses, and got coolant all over the place. what a mess. I still don't know how to avoid getting coolant all over the place.
Old Mar 3, 2003 | 03:55 PM
REVHED's Avatar
Hunting Skylines
You can plug the holes in the block so coolant doesn't **** out whenever you take the manifold off. I used a couple of 20mm freeze plugs and some RTV.
Old Mar 3, 2003 | 03:56 PM
pillage6's Avatar
Drain the coolant from the plug beneath the oil dipstick.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
