still problems after cold-solder "fix"
Old Aug 19, 2001 | 10:53 AM
virtego13's Avatar
Exclamation still problems after cold-solder "fix"
A couple of weeks ago, i had my CPU re-soldered because of a few malfunctions in my car. for example. the biggest problem was the IP lights never worked, so i put in a new headlight switch-box. the IP lights worked for about 3 or 4 days before they went out again. also, the clock and the windshield wipers have intermitent problems. the dome lights don't work and the rear hatch light sometimes works, and sometimes doesn't.
please note that i had a friend of mine, who is an electical engineer re-solder the CPU, so i am certain he did a good job. please tell me what to do. this is becoming a real nuisance.
PLEASE HELP!!!
Old Aug 19, 2001 | 11:12 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Cold solder joints in circuit boards is a cronic problem with 2nd Gens. You just keep attacking them individually re-soldering as the case calls for. Sooner or later you'll get em all. Nuisance in the mean time, but nothing that should put your care out of commission.
Switch's, conversly, usually only get dirty contacts over time which only calls for taking them out and clean with a pencil erasor or lite grit sand paper or file.
My guess is you have a power source problem common to all of the lights you mention.
FD3S.org has an '88 Mazda shop manual you can access online so long as your computer has Adobe Reader. This resourse has to be the most valuable I've seen online. Again, cudos to you Dave.
Go to the schematic section at the back and find the section that deals with interior lights. Find all these things you mentioned and trace back until you find a common point then look there.
My guess is you have a switch or connector connection problem somewhere.
Good luck.
Old Aug 19, 2001 | 01:21 PM
virtego13's Avatar
okay...
sounds like you know what you are talking about. i have always been a little reluctant to work with electrical stuff. i will go to the site and give it a try. thanx a bunch... i will let you know how it works out.
Old Aug 20, 2001 | 09:42 AM
ltolisano's Avatar
Be careful with the re-soldering bit. Not only did Mazda have a poor soldering process, but the PCBs are of poor quality. I found some lifted pads in my wiper unit that caused the intermittent wiper portion to fail - it wasn't the standard relay problem. Make sure you use a low-watt iron, and don't hold it for too long or else you'll be lifting some pads as well.
Old Aug 20, 2001 | 11:25 AM
go_speed_go's Avatar
Th wiper switch and clock are definately their own soldering projects. The wiper switch typically needs a new relay soldered in and the clock needs a similar treatment that the CPU got.
clock fix is here: http://www.teamfc3s.org/faq/FAQ.html#s2ci
Wiper fix is here: http://2ndgenrx7.freeservers.com/techmaster.html
Old Aug 20, 2001 | 02:13 PM
CYAL8R's Avatar
i need a heater control fix! the only way i can turn the heater all the way off is if i reach all the way under the dash and spend an hour finding the dampering switch......SOMEONE PLEASE HELP
Old Aug 20, 2001 | 02:28 PM
ltolisano's Avatar
Have you performed the necessary re-soldering of your logicon?? This will fix numerous HVAC related problems.
Old Aug 20, 2001 | 03:18 PM
HOZZMANRX7's Avatar
Alternatively, just replace the Logicon. Its easy to remove and replace, just a couple screws. I see them all over the pull you own parts wrecking yards out here. Fairly inexpensive.
Old Aug 20, 2001 | 03:23 PM
ltolisano's Avatar
True, but you'll most likely have the same or different problems with a different logicon - unless it was resoldered!
Old Aug 20, 2001 | 06:25 PM
[bnd]'s Avatar
try cleaning the connections for your dome lights and rear hatch light. they can get dirty sometimes and cause poor connections. i know, because the previous owner of my car was a chronic smoker. i'm still vacuuming cigarette ashs and smoke out of my car and i'll probably never get it all.
brandon
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
