Funky/Scary engine sound
Old Aug 17, 2001 | 09:40 PM
Winnipeg85GSL's Avatar
When my car gets to about 4500 RPM a funky kinda groan like sound happens? Should i take it super easy on my car? Or is this because the rotor is spinning super fast?
Old Aug 17, 2001 | 10:16 PM
Pele's Avatar
Right near Malloy
You carbureted? Coincidentially, thats about when the seccondaries kick in.
Give some more info.
Old Aug 18, 2001 | 01:27 AM
Jeff20B's Avatar
Lapping = Fapping
Mine kicks in hard at 3000RPM, below that they kick in, but it's not as forceful. Then again, at 5000RPM and above, my power drops off dramaticaly and it vibrates badly at 6000RPM. Might be my flywheel. I'm not done troubleshooting my 13B yet.
Isn't there some sort of honking noise that an emssions device produces? Or was that at idle? Just throwing questions out there.
Old Aug 18, 2001 | 01:33 AM
cpt_gloval's Avatar
KARATE EXPLOSION
Re: Funky/Scary engine sound
mine does that at about 2500 when i have a lot of load on it (in 4th gear and trying to accelerate or something).
Old Aug 18, 2001 | 03:44 AM
Ya my car is carburated. I cant really describe the sound either its just weird.
Old Aug 18, 2001 | 06:13 AM
Felix Wankel's Avatar
Super Newbie
Does it happen and go away quickly or does it happen and keep happening until redline?
Old Aug 18, 2001 | 11:55 AM
It doesnt go away, i dont know if it goes all the way to redline because i dont push it to that but ive almost been there and it still happens.
Old Jun 5, 2002 | 03:53 AM
kylekyle's Avatar
Yes. it is problem with karb.
Old Jun 5, 2002 | 09:38 AM
crankit's Avatar
coasting valve? Vacuum secondaries coming in too soon Did you remove the spring to make it mechanical linkage to bypass the vacuum?
Old Jun 5, 2002 | 10:29 AM
TheAMAZINGNorad's Avatar
Just wonderin..how can you be sure that the secondaries are opening? Because i really dont feel or hear anything different as i hit 3000-5000 range...
Hum..didnt see that this post is old as hell..grr.strop bringing back old posts! Its confusing!
Old Jun 5, 2002 | 04:08 PM
Just to clear it up it was the air pump, it was disconnected and was making crazy sounds.
elfking
Aug 19, 2015 09:48 PM
rx7jocke
Aug 15, 2015 03:36 PM
befarrer
Aug 14, 2015 04:18 PM
