Vaccum Pressure Inquiry??
Old Aug 17, 2001 | 08:28 PM
Mr. Mahtab's Avatar
I have a 6400 mile Pettit ported engine My vaccum at idle is -13 lbs. constant. However when I am decellerating the negative pressure can go to -19 to -21. I have been reding on other posts that it should be -17 to -20 at idle. Is this normal? I checked and double checked the vac lines for any loose ones and all is good.
Old Aug 25, 2001 | 12:29 PM
KZ1's Avatar
KZ1
that is only for stock, ported engines will be less, becasue they flow better. Call pettit they will know.
Old Aug 25, 2001 | 02:09 PM
RXJJang's Avatar
under construction...
i have a ported motor by Farrel , and I get a vac. pressure ~13-14. I wouldn't worry, your numbers look ok.
Old Aug 26, 2001 | 12:19 PM
weaklink's Avatar
Resident Retard
So what if the vac pressures are low??? what does that mean?
13
Jan 9, 2018 11:19 AM
alexdimen
20
Oct 23, 2015 01:50 PM
sinistersam
Sep 13, 2015 07:17 PM
t-von
Sep 10, 2015 01:56 PM
