ported water jackets?
Old Feb 20, 2003 | 02:50 PM
stlFD's Avatar
official pussy inspector
Question ported water jackets?
Has anyone had their water jackets grooved? If so, who does this? How much? Was it worth it?
Andrew
Old Feb 20, 2003 | 04:02 PM
tookwik's Avatar
VIP - Very Irish Person
what are you talking about?
Old Feb 20, 2003 | 04:09 PM
crazysuprakid's Avatar
PM Jedon I know he had it done a while back...
Old Feb 20, 2003 | 04:22 PM
maxcooper's Avatar
WWFSMD
I did. Mazdatrix did it. I cannot quantify the effect, but MazdaTrix and Racing Beat both recommend it for severe duty, so it seems like a useful mod.
-Max
Old Feb 20, 2003 | 04:35 PM
teamstealth's Avatar
Ozone Depleter
what exactly is grooving your water jackets?? It sounds like making little grooves in the water jackets allowing more water to flow through, right?? @ least thats what it sounds like to me
Old Feb 20, 2003 | 04:36 PM
meddle's Avatar
I'm doing oil passages and water jackets when I have my reman ported.
Old Feb 20, 2003 | 09:19 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
just for your guys info, the new FD rotor housings here in japan, so im assuming they do in the states as well, have these machined grooves into the water jackets around the spark plug holes. I used FD housings when I rebuilt my FC..I cant testify as to if they help or not, but I have a 3 core koyo rad, streetported motor, perma-cool 1600 cfm fan running constantly, and i never saw above 80C on my water temp guage
Old Feb 20, 2003 | 09:39 PM
poss's Avatar
Slower Traffic Keep Right
i think the goal isn't so much for flow, but to increase heat transfer surface area.
Old Feb 21, 2003 | 07:51 AM
vudoodoodoo's Avatar
Making it not smooth. Normally it would be smooth, but if you make grooves or make the surface go up and down like little waves, the coolant will touch more surface area. That will help the coolant absorb more of the engine heat, hence better cooling.
Old Feb 21, 2003 | 11:47 AM
Jedon's Avatar
Slave2TheFD
I had it done, $200
Like the others said, hard to quantify since I did so many upgrades when putting the new engine in, but my engine builder did it to all his 12A bridgeport race engines.
Old Feb 21, 2003 | 12:53 PM
SPOautos's Avatar
Hey, where did my $$$ go?
WOW, I didnt know that. I guess this is where the engine builders here in the states got the idea, and I just thought they were creative haha
STEPHEN
Old Feb 21, 2003 | 03:14 PM
stlFD's Avatar
guess I should have checked back on this thread earlier. Anyways, putting grooves in the water jackets should be similar to putting a heat sink on a computer chip, if you're familiar w/ electronics. It should help dissipate heat better. I was just reluctant to try it because I didn't want to blow a a bunch of money on something that might not work. I think that I might just save the money and put it towards ceramic coatings. I have heard a lot of good stuff about em'.
Old Feb 21, 2003 | 09:03 PM
SleepR1's Avatar
Had mine done @ KD Rotary when I had them build me a street ported motor. Dave also does the oil and coolant passages.
josef 91 vert
14
Sep 17, 2015 09:22 PM
msilvia
15
Sep 11, 2015 12:13 PM
mulcryant
Sep 9, 2015 05:24 PM
