Anyone really notice a difference between M2 Med/Large IC?
Old Feb 18, 2003 | 01:57 PM
radkins's Avatar
Thinking of upgrading (the Large just looks soo damn cool), but I have heard that I won't be able to tell a difference other than the Large takes longer to heatsoak.
Old Feb 18, 2003 | 01:59 PM
Garrett's Avatar
The M2 large has a larger pressure drop. I forget the exact figure.
Old Feb 18, 2003 | 02:04 PM
matty's Avatar
i dont "think" that is the case anymore
Old Feb 18, 2003 | 02:07 PM
matty's Avatar
Re: Anyone really notice a difference between M2 Med/Large IC?
dont discount the effects of heatsoaking especially if u drive it on the street...
Old Feb 18, 2003 | 02:32 PM
ttpowerd's Avatar
HARRRRRRRRR
Pressure drops are about equal
Old Feb 18, 2003 | 09:37 PM
7racer's Avatar
The pressure drop is no longer true with the new M2large...just look at the later right-ups of the sports compact project car...
I just hope Kevin Wyum...and I guess we should call them ASP intercoolers now....chimes in. I am just waiting for the refabb'd pipes that clear the airpump better. (better fitment is good for me)
With the recent emissions tightening in Texas....visuals are suppose to be taking place...
Old Feb 18, 2003 | 10:08 PM
radkins's Avatar
Re: Re: Anyone really notice a difference between M2 Med/Large IC?
I have a good IC fan on it.
Old Feb 18, 2003 | 11:39 PM
kwikrx7's Avatar
You're not going to notice any hp gains when foing with the M2 Large - they cool about the same. The Large has a little advantage when it comes to cooling but only by about 6-7 degrees from what I remember. The M2 medium had the best pressure drop of any IC (only .5) - I've not read about the new M2 Large having equal pressure drop but have heard it a few times. There are many 400+ rwhp FDs running around with M2 medium size ICs or similar copies - M2 Large looks awesome though.
Old Feb 19, 2003 | 04:17 AM
TomsRX7's Avatar
I have the M2 medium and I don't think the large would offer much of a difference. Either one will suffer heat soak so if that is an issue, I would go with a front mount.
Aside from the heatsoak issue, once I'm up and running at normal speeds of at least 40MPH or higher, (out of the bumber-to-bumper traffic I deal with here in California), the M2 medium works great, even to the point where I'm actually surprised . Without being too exact or scientific, the IC inlet pipe will be fairly hot, say 140F for example, and the outlet side will be oh, I'd say, about 5-10F above the current outside air temp. In other words, the outlet pipe is almost cold.
Therfore, either go with the M2 (now ASP) Medium or else go with a FMIC. The headache of relocating the battery (and other details?) of the M2 large are simply not worth the un-noticeable difference.
Just my $.02 though.
-Tom
Old Feb 19, 2003 | 07:26 AM
matty's Avatar
-Tom
this is exactly the reason i went with the medium.
Microtech
Nov 21, 2015 10:20 AM
t-von
Sep 10, 2015 01:56 PM
Ian_D
Sep 6, 2015 10:38 PM
