WHoohoo, just got my 87 volvo intercooler, but its oily inside, how can I clean it?
Old Feb 14, 2003 | 04:11 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
It looks to be in perfect shape. zero bent fins and I pressure tested it to 25 psi.
But its oily inside. The side tanks are plastic and I think the core is alluminum, but its painted so I cant be sure.
what can I use to clean the oil out.
I could be wrong but wont the oil act as a insulator.
Old Feb 14, 2003 | 10:23 PM
JScott's Avatar
Just fill it full of mineral spirits or a mixture of water and "purple" degreaser. Shake it around and rinse it well, should be fine. I wouldn't use laquer thinner as it may be too harsh on the plastic(if it does have it).
Old Feb 15, 2003 | 07:16 AM
bkapold@aol.com's Avatar
That''ll work too......Simple green and water seems to work pretty good to....FYI
Brad
Old Feb 16, 2003 | 02:02 PM
Domestic513's Avatar
I just use gas. out about half a gallon in it. Shake the **** out of it for awhile. then dump it out. Then get an ait compressor and blow it till it's completely dry.
Old Feb 16, 2003 | 02:40 PM
I used to use gas in my DSM intercooler It worked excellent i just put the gas and and shook it around for a bit then rinsed it and all the oil was gone
tiger18
Sep 3, 2015 08:27 PM
