upgrades on rebuilt engine
Old Feb 12, 2003 | 01:32 PM
mysterx7's Avatar
Im currently having my engine rebuilt...Im just wondering if it would be a good idea to have bolt on parts added on while the engine is still apart...the upgrades are radiator, intercooler, air intake, down pipe, and a catback....please advise....thanks in advance..
Old Feb 12, 2003 | 01:49 PM
dubulup's Avatar
development
you could also...Port the motor and the wastegate, and why not have some port matching in the exhaust manifold and such...but what do I know???
Old Feb 13, 2003 | 10:38 AM
mysterx7's Avatar
thanks, i forgot to list the street port...i was just concerned that it might not be good for the engine if it had all those bolt ons right away.....i was bacically thinking that it would just be very convenient for the technicians to install them.....
Old Feb 13, 2003 | 11:06 AM
ttpowerd's Avatar
HARRRRRRRRR
yes do it while it is out. Makes things much easier! The cat back is not necessary to do right away but really matters not either way. What do you mean "not be good for the engine"? Just don't rag on it and make sure you have the proper fuel upgrades for these things you are talking about. You will certainly need a new ecu, maybe upgrade the fuel pump, replace the fuel filter (if you have not already), and depending on what boost levels you want to push - injectors are nice and easy to install while the engine is out. At the least get the injectors cleaned before reinstalling them into the new engine.
Old Feb 13, 2003 | 11:22 AM
es's Avatar
es
You should consider the internal motor upgrades. Viton Oil O-rings, E-shaft check ***** replaced with .220" Webber carb jets, Thermo-pellet replaced with plug, Teflon/silicone inner coolant O-rings increased side clearance rotors.
Get the racing beat catalog, it explains in detail all of the above modifications.
Upgrading oil cooler/coolers is a good idea also.
Old Feb 18, 2003 | 12:24 PM
mysterx7's Avatar
i appreciate the advise, i will look into it and talk it over with the technician....thanks!! im getting excited..but i just want to have the car a little more reliable than before but with a little more punch...
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
