Misting of Gas??????
Old Feb 12, 2003 | 11:00 AM
I know that gas is leaking from the drivers side of my carb. Im thinking it the accel pump. Does anyone have any ideas on what could be leaking, or should I just replace the diaphram.
One more thing. When I shut my car off, I took off the top of my air cleaner, and there was mists of gas still in the carb constantly coming out for about 5 mins. What is this a sign of. Or is this completemly normal.
All your help will greatly be appreciated.
Old Feb 12, 2003 | 11:06 AM
damon's Avatar
Sounds like what happened to my car when the floats wernt set properly, causing it to flood over a little.
Peace
Old Feb 12, 2003 | 11:08 AM
If I got a carb rebuild kit, would that fix the problem?
Old Feb 12, 2003 | 12:53 PM
rx7_freek's Avatar
Code and Rotary Hacker
Well, I wouldn't go that far just yet...but rebuilding a carb properly can definitely be a good thing.
First I'd want to get my hands on a Haynes manual and a metric ruler (mm) and check/reset the float level according to the specs listed.
Old Feb 12, 2003 | 04:22 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
by the time you've got enough of the carb apart to set the floats, you might as well rebuild the whole thing, IMHO. So I'd say, rebuild the sucker!
Does anyone else think that Damon's sig is a bit excessive?
Old Feb 12, 2003 | 05:39 PM
By rebuilding the carb, will i expect to see an increase in gas milage?
Old Feb 13, 2003 | 12:10 AM
Rotor13B's Avatar
Wassup!!
I would say so. By rebuilding your returning the carb to it's most efficient status. (don't forget tuning)
Old Feb 13, 2003 | 12:16 AM
RotorMotorDriver's Avatar
Seven Is Coming
My carb mists like that after running, and I dont ahve any leaking issues or anything...
~T.J.
Old Feb 13, 2003 | 10:55 AM
It didnt seem like that big of a problem, but more irritating!
Thanks for the info!
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
musker
Oct 1, 2015 05:58 PM
rattlehead
Sep 25, 2015 10:55 PM
