Power FC Need input, is it possible to get 18 psi on the power fc
Old Aug 16, 2001 | 08:31 AM
AARotary's Avatar
Thumbs up Need input, is it possible to get 18 psi on the power fc
I will be going to KDR at the end of this month to get my car dyno and tune to 18 psi using Apexi Power FC and AVCR. Dave at KD told me that it is possible to run the power FC and AVCR to get 18 psi without the boost control kit. I have heard many members on the forum saids that you can only go up to 15 psi on the power fc and anything beyond it you will have to get the boost control kit and others stated that you can boost up to 18 or 20 psi and varies.
Old Aug 17, 2001 | 12:38 AM
Xcessive's Avatar
20 PSI
I am running 20 PSI on the street with the PFC,550cc@1300cc
injectors,AVCR,and maps from XS engineering with no problem
so far. My dyno's Wideband O2 shows 11:1 AF all the way up
to 7500 RPM with no problem. My turbo is a XS TO4S.
Xcessive
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
