spring on the wastegate question
Old Feb 11, 2003 | 03:46 PM
eddierotary's Avatar
back with rotaries
i heard about there spring for the wastegate to lower or raise the boost. do they sell spring for stock TII turbos? thanks
Old Feb 11, 2003 | 06:12 PM
Node's Avatar
no idea, but maybe someone would know if other wastegate springs could be used.
Why not just make a hardware boost controller.
Old Feb 11, 2003 | 06:51 PM
HeffBoost's Avatar
Keep Right Except to Pass
Isn't the actuator sealed?
Manual Boost Controller is the easy way to up your boost.
Old Feb 11, 2003 | 08:00 PM
back with rotaries
is not to raise the boost is to lower it. im planning to get only 6 psi because im using N/A ecu.
Old Feb 11, 2003 | 08:23 PM
Node's Avatar
ick
Old Feb 12, 2003 | 06:26 AM
HeffBoost's Avatar
OK
Skeese
65
Mar 28, 2017 03:30 PM
AXA
Sep 5, 2015 10:06 AM
