Single turbo omp question for fd
Old Feb 10, 2003 | 11:01 PM
a question for you single turbo guys that use the factory omp on fd's
is this something that I should be concern with when I go single, the vacuum line on the oil nozzels?
I was just reading this and was wondering if I should be worried about it
https://www.rx7club.com/forum/showth...hreadid=135880
I assume you just put the vac line to the turbo inlet so the nozzel does not see boost?
there are single turbos that do not run premix right?
thanks in advance
Old Feb 17, 2003 | 01:19 AM
hmmm, no one? So everyone who's running single in a FD use premix?
Old Feb 19, 2003 | 07:03 PM
IgoSlow's Avatar
well i don't run it becuase my haltech doesn't support it. So i have to premix. I hear there are alternatives like stand alone omps you could by from other vendors.. somone has a post somewhere on the forum about it. The new haltech e11 does support the omp i believe. I'm just going to remove it and block it off with the plate i bought from k2rd.. hope that helps...
Old Feb 19, 2003 | 08:49 PM
mjw's Avatar
mjw
Re: Single turbo omp question for fd
That is exactly what I did, ran a vac line to a nipple on the intake piping before the turbo. This is with a PFC though, not sure what other EMS support it.
Matt
Old Feb 19, 2003 | 09:17 PM
es's Avatar
es
I pulled the 90 degree nipple out of the LIM (went to EGR I think) drilled a small hole in the compressor housing behind the turbo & pressed the nipple in there with some locktite to seal it.
I'd post pics but it just wont go through.
Old Feb 19, 2003 | 10:35 PM
Carl Byck's Avatar
Mad Man
here is a link to some Mechanical, and electronic OMPs. I have an E6K with an 88 OMP, works fine, but I think that's the only type that does. Carl http://www.rotaryaviation.com/oil_in...p_adaptors.htm
Old Feb 21, 2003 | 02:03 AM
cool , thanks for the info
sherff
Feb 24, 2019 12:09 PM
