GSL-SE motor questions...
Old Feb 10, 2003 | 03:32 PM
cpt_gloval's Avatar
KARATE EXPLOSION
how much horsepower can one expect to make with a GSL-SE 13b and a weber or dellorto carb and appropriate fuel setup?
additionally:
- will a 12a transmission bolt right up to an SE motor without modification?
Old Feb 10, 2003 | 04:25 PM
RotorMotorDriver's Avatar
Seven Is Coming
Yes.
~T.J.
Old Feb 10, 2003 | 07:13 PM
RacerX7fb's Avatar
paradox
With a full headered exhaust sytem it will make around 170 crank HP provided it is tuned properly and the engine has healthy compression
Old Feb 10, 2003 | 07:37 PM
680RWHP12A's Avatar
use a weber 48 dcoe, for the best power increase! and dual exhaust!
Old Nov 15, 2003 | 05:12 PM
milkman2k52's Avatar
sorry to ask such a basic question, but is there more power to be had with a carb than stock fuel system w/ injectors and raised fp or something?
Old Nov 15, 2003 | 09:54 PM
82transam's Avatar
Never Follow
From what I've heard the stock FI system isn't all that good, so a carb will make more power. Then again FI is better for climates that change a lot, such as here in the northeast. Carbs can be real bitch in the winter. So like anything its a tradeoff.
Old Nov 16, 2003 | 02:16 PM
Forseti's Avatar
if it's not from an 84 or 85 the 12a transmission will have different gear ratios. ..but this may be favourable in your case.
doritoloco
Sep 5, 2015 12:41 PM
