Aftermarket air cleaner available?
Old Feb 10, 2003 | 10:48 AM
Randy Nix's Avatar
My air filter got burned up. I thought I would just get a chrome aftermarket filter with open sides but the throat opening is too big. Has anyone fabricated an adapter or does anyone know of a supplier for an air filter that will fit the Nikki carb? Thanks.
Old Feb 10, 2003 | 10:55 AM
RotorMotorDriver's Avatar
Seven Is Coming
Just cut the sides off of yours. Only leave vertical pieces where the snap clips go to hold the lid on, then throw a K&N in there and call it good .
~T.J.
Old Feb 10, 2003 | 10:56 AM
357's Avatar
357
Stratoflattener
A couple of the people here (myself included) have replaced the stock upper air box plate (the blue, removable disc that says "Mazda Rotary") with a plexiglass disc which only covers the top of the air filter, effectively opening up the "donut-shaped" area around the filter, and allowing a more efficient flow of air into the engine. To attach it, you just buy a 8mm 1.25 module coupler nut and an appropriately sized bolt, and replace the wingnut with the coupler nut, and then drill a hole in the plate, then run the bolt through that, threading it into the coupler nut.
I'm not entirely sure that's what you were getting at, but thats one option to increase airflow into the carb, regardless of what filter you have (although it does work better with a K&N, due to their higher flow capacity, and smaller outer diameter).
Old Feb 10, 2003 | 11:04 AM
inittab's Avatar
I read your email
Here's a pic of my intake. It's very similar to what 357 has described. I run a K&N filter.
Old Feb 10, 2003 | 11:07 AM
357's Avatar
357
Stratoflattener
inittab - Is that a Bonez, or did you just paint yours blue?
Old Feb 10, 2003 | 11:10 AM
Randy Nix's Avatar
My stock filter burnt up. The rubber gaskets under and on top of the air filter are gone. I saw these gaskets in VB for $22 but I'm cheap. I want something better and prettier if I'm going to spend money. I saw that Racing beat has one but it's $50 with no filter. If I could figure out how to adapt the 3 7/8" opening of the Nikki to the standard 5" (approximate) 4 barrel air filter I could get a new chrome filter with element from Auto Zone for $16.
Old Feb 10, 2003 | 11:14 AM
inittab's Avatar
I read your email
Pretty sure it's a Bonez. It came with the car.
Old Feb 10, 2003 | 11:29 AM
Seven Is Coming
I think theres a company that mkes one that will fit on our carbs...I know Ive seen it around, I just cant remember who.
~T.J.
Old Feb 10, 2003 | 11:57 AM
rxtasy3's Avatar
Re: Aftermarket air cleaner available?
I bought one of those awhile back from either from AutoZone or Advanced. It was the 6 5/8" round air cleaner, and it came with a black plastic adapter and was surprised that it fit the stock carb. Good luck.
Old Feb 10, 2003 | 12:04 PM
I bought a new Air Cleaner Assembly from Racing Beat. It costed 50 bucks and the foam filter is 15. It is excelent, here is a link to it.
http://racingbeat.com/resultset.asp?PartNumber=16531
Thomas Stifter
Old Feb 10, 2003 | 07:29 PM
357's Avatar
357
Stratoflattener
Finally got pics of mine:
And a closeup of the way i attached it:
Yes, those are cracks. I was being stupid with the power drill that day. If you have trouble seeing the pics, go to My Rx-7 Gallery and then click on the "My Rx-7" gallery. They should be the last 2 pics on page 2.
Old Feb 10, 2003 | 07:36 PM
85RX7GS's Avatar
Hey! That's my design! I'm glad you like it and decided to use it
Old Feb 10, 2003 | 07:38 PM
Lt. Dan's Avatar
I like my racing beat air cleaner....
Dan
Old Feb 10, 2003 | 08:48 PM
someone82's Avatar
I just bought one of the cheap chromee' air filters and adapter from pepboy's for 15 bucks and it worked great when I still had the nikki.
matt
Old Feb 10, 2003 | 09:46 PM
Seven Is Coming
Youre design? .
~T.J.
Old Feb 10, 2003 | 09:52 PM
Rx7carl's Avatar
Airflow is my life
Hey I like the models! I have that Gemini model too. Havent started it though. Looks good. The B-17 is nice too.
msilvia
15
Sep 11, 2015 12:13 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
