how to hook up air/fuel ratio gauge??
if you have an autometer air/ fuel gauge (and basicly all air/fuel gauge) you have to get a single wire O2 sensor like one out of a S4 rx7's and make a hole in the exhaust near the manifold and weld a nut big enought for the O2 sensor. and hook the purple wire to the O2 sensor wire. then the red wire to a pos cable coming from the swich and the black that is the ground. is simple
it's easy as....just go to an exhaust joint (if you haven't got a welder) and ask em to put in an O2 sensor bung. Probably cost less than 60 bux...
Then the sensor just screws into this.
For the sensor the VT commodore ones are meant to be pretty good aren't costly.
Trending Topics
location or link for either VT commodore or a heated one and differences since I am about to do just this.
Basically a heated one just has three wires. 2 for power and earth for the heater and then the signal wire. Some even have 4 wires with the eatra wire being a earth for the signal circuit.
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
