oilly spark plugs
Old Feb 4, 2003 | 05:53 PM
dansuxx's Avatar
Angry oilly spark plugs
does anyone else think that it is a really bad sign when my sparkplugs are pretty oily. car just wouldn't start last night, pulled my plugs and cranked it and oil sprayed spightly from my spark plug ports. Is this a sign of a blown seal. any help would be great. i'm hoping it's not my third engine in three years
Old Feb 4, 2003 | 09:54 PM
inittab's Avatar
I read your email
Re: oilly spark plugs
It could be a sign of a blown oil seal OR it could be a sign that your OMP (Oil Metering Pump) is stuck wide open.
oil sprayed from you spark plug holes? Da don't sound good.
Old Feb 5, 2003 | 08:52 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
First thing to check would be to disconnct the OMP lines from the carb, making sure make some provisions to catcht he oil that will presumable squirt out. Then pre-mix some gas with 2-cycle oil and throw it in the tank. Try the car. If it works, like the man said, your OMP is shooting too much oil.
That being said, I've never heard of a stuck OMP.
OTOH, you could try the ATF trick. One of your seals could merely be stuck, not blown. Check www.mazspeed.com for details. (Go to the facts section)
Good luck with the car.
Old Feb 5, 2003 | 09:48 AM
jeremy's Avatar
male stripper
atf trick is for unsticking apex seals. his problem would be side seals is seaing is the problem. i'd try the omp route but more then likely your side seals are leaking. on an up note, time to go street port.
Old Feb 5, 2003 | 09:50 AM
Richard Miller's Avatar
Damn, it did start!
my OMP was stuck open and was causing the same problems, later today I will be checking out to see if the problem has been fixed
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
