Should I replace my 1988's ECU?
Old Aug 14, 2001 | 02:50 PM
TBoost's Avatar
Even if this is true, you aren't going to gain any HP from it.
Stock ECUs aren't made for power..
-M
Old Aug 14, 2001 | 04:06 PM
vaughnc's Avatar
knowledge junkie
I've seen some chip replacement posts (aka ECU reprogramming) that basically maxes stock fuel, heightens fuel cut, and allows more boost (in combination with the boost bill and waistgate I believe).
They issued a 2nd ECU in either 89 or 90 that was better quality boards to prevent some of the grounding and cold sauder joint problems.
Old Aug 14, 2001 | 11:36 PM
Keith's Avatar
Wink
The '89 and above ECU is not a drop in replacement for the '86-'88 ECU. However, it is true that you can display the ECU codes in real time - we have that setup in my '87 TII. Also, there is a third output that is useful, the O2 sensor output. While not as good as an A/F ratio guage, it tells you if you're leaning out, and that's very important. Check out the following site: 2ndgenrx7.freeservers.com/technical information. Look at the article on Reading Error Codes for a complete writeup. Peace!
Irv, Keith's dad
Kyo
Apr 13, 2019 09:24 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
