Tune-up..What are the best plug wires, cap, plugs etc..
Old Jan 28, 2003 | 07:07 PM
cjf's Avatar
cjf
I want to do a total tune up on my gsl-se and was wondering what brand of plugs (I think NGK is a no brainer), plug wires, dist. cap, rotor etc...what else do you have to do? I am replacing the fuel filter too. The car runs ok but I have no clue as to when a tune up was done or if it was ever done?? I assume it has but....you never know I guess. It has 82,000 miles. I know for sure the clutch has never been done and it seems fine??!!!..I guess I will leave well enough alone. Should I do the same with the tune up?? Leave it alone? Like I saidm runs good, lacks the power "I" think it should have. Maybe all I need is to have the timing checked??..I appreciate your comments/suggestions...cjf
Old Jan 28, 2003 | 07:10 PM
85RX7GS's Avatar
Spark Plugs
Old Jan 28, 2003 | 07:25 PM
cjf's Avatar
cjf
yeah, I saw that, that was why I said "ngk a no brainer"...thanks though....cjf
Old Jan 28, 2003 | 07:29 PM
85RX7GS's Avatar
That's not the only reason why I pointed that out. There are also some interesting combo's of NGK plugs that you can use - such as BR8EQ's on the leading and BR9EQ's on the trailing.
Old Jan 28, 2003 | 07:34 PM
mwpayne's Avatar
Admitted 'rexaholic'
I've used NGK wires as well, mostly 'cause they look good (blue) and seems like there's always a new set on ebay for around $15.
Supposedly it's best to use the mazda cap & rotor, as they will last longer.
Old Jan 28, 2003 | 07:43 PM
cjf's Avatar
cjf
sorry 'bout that, Iwill look at that closer. Did you do it and if so, any difference??
Old Jan 28, 2003 | 08:23 PM
85RX7GS's Avatar
No problem cjf.
The next time I switch my spark plugs, I plan on running this configuration. I'll be due to change my spark plugs soon enough.
Old Jan 28, 2003 | 08:42 PM
jutny's Avatar
SA all the Way!
what's the benefit of the br9eq's on the trailing?
Old Jan 28, 2003 | 08:46 PM
85RX7GS's Avatar
Originally posted by inittab
The trailing plugs, from what I understand, endure a lot more heat than the leading, that's why I run the colder "9" plug. You'll also notice that Mazda started recommending colder trailing plugs for all rotaries after 1986. <speculation> Perhaps this is because Mazda learned something about spark plug behavior and decided to make it a mfr recommendation. </speculation>
Old Jan 28, 2003 | 08:57 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I'm using a set of Accel 300+ "Thunder sport" wires and am very pleased with their performance. They have a spiral-wound metal core that doesn't wear out like normal carbon string wires, and the spiral winding gives them a resistance of 150 Ohms/ft. for radio noise suppression. Plus, their red jacket looks cool.
I have a couple of sets of the blue NGK wires, but the Accels are noticeably better, IMO. I'd like to find a source for some Mazda rotor and cap sets that don't cost an arm and a leg, myself. I've used a lot of different spark plugs in different rotary cars, and have settled on the NGK BR8EQ14 as the best balance between power and longevity. The best power was achieved with NGK B8EV plugs, with the most difference being felt in the midrange. They didn't last long enough for me, though.
Old Jan 29, 2003 | 12:29 PM
cjf's Avatar
cjf
how does a set Accel 300+ plug wires give you performance over normal plug wires..how are they "noticeably" better??.. in what regard...thanks..cjf
Old Jan 29, 2003 | 06:53 PM
Wankelguy's Avatar
The car just seems to have a smoother midrange with the Accels vs. the NGK wires, 'course that's a seat-of-the-pants observation. They do have a lower resistance per foot than non-metal core wires, and they don't wear out like old style carbon-string wires do. So theoretically, their performance should not degrade with time. I got them at the junkyard for FIVE BUCKS, how could I go wrong?
The1Sun
Mar 18, 2018 11:08 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
