Moded 88 GTU vs moded 00' Civic Si
Old Aug 14, 2001 | 07:02 AM
Rx7Boi's Avatar
well the other day i raced a 00 Civic Si (vtec) 2/3 runs, and lost 2 times (very bad start both times) last race tied, i had a decent start, we only got upto 55-60 or so, i only have i/h/e, he has i/h/e power pulleys, AEM fuel rail, Venom Injectors. but he is getting cams and cam gears, but next time i want to run away from him, what should i do? i have these mods in mind
1. Remove 6port sleeves
2. Ported 89 intake manifold
3. Removing A/C
4. Redline oil in tranny and diff (more hp to the ground)
5. Putting my e-fan and UD Pulley on
6. ACT Clutch, 9lb Flywheel
7. Crane Hi-6
8. G-Force ECU will help?
9. wait for Agent_D's cold ram air
think thats enough?
Old Aug 15, 2001 | 09:03 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Re: Moded 88 GTU vs moded 00' Civic Si
3. Removing A/C
7. Crane Hi-6
think thats enough?
the light flywheel will hurt you in a drag race...
Get rid of some weight.
Brad
Old Aug 15, 2001 | 09:44 PM
That redline oil stuff actually does get more HP to the ground??? I've never used it.....interesting
Old Aug 15, 2001 | 11:50 PM
fc3s.org's Avatar
OG
The Redline oil in the tranny will make shifting easier. This is great in tranny's that are older and in need of a rebuild. It hides problems so you can go longer without rebuilding your tranny.
As for the Diff, since it is a 88GTU, if I'm not mistaken, it has an LSD diff. The Redline fluid will make the rear run smoother and make the LSD act as it should. It would also lower temps back there.
As far as HP with either of these? I doubt it. Maybe 1/4HP in friction reduction.
Throw in a 50 shot of NOS =)
Old Aug 16, 2001 | 04:08 AM
Rx7Boi's Avatar
For sure a 50 shot, oh my engine is also starting to die... soo.. i'm going to throw in some Auto trans fluid to help it..
Dave, you put a 50 shot on the Project '86 right? how much did it cost?
was it hard to install?
what should i take off to lose some weight? a/c, that crap under the seats, 17lb sparco racing seats, hey i heard the stock seats weigh 50lbs each!!
plus my three 10" mtx subs dont help
Old Aug 16, 2001 | 04:11 AM
Rx7Boi's Avatar
msilvia
164
Mar 8, 2020 08:00 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
befarrer
Sep 22, 2015 09:33 AM
