SAFC Throttle sensor trouble...
Old Jan 26, 2003 | 01:04 AM
BlackRx7's Avatar
Daily Domestic Killer
Okay I jsut installed my new 2nd gen APEXi SAFC, and when I press the throllet like 55-60% down it goes to 100% on the SAFC, did I do something wrong? I mean my low throttle setting is like never used.......I did break a bolt top off the braket for the throttle line, it was the bottom bolt on the backside of the intake mani, but I did torque down the top bold so it won't move and made it even with the bottom bolt hole, my question how do I get that bottom half out? gonna be a bitch......it hasn't moved and is still where is should be but why is the SAFC throttle read wrong, is there anythign I can do to change it??
Old Jan 26, 2003 | 01:07 AM
Jimmy325i's Avatar
No longer cares
you have a second gen.... the tps sensor reads 100% at 1/4 throttle. this is normal.
really hate to say this, but searching would have clued you in to this. its been mentioned numerous times before.
Old Jan 26, 2003 | 01:09 AM
Scott 89t2's Avatar
SOLD THE RX-7!
normal for 86-88. tps reads full at 30% throttle or so.
set your high at 99% and low at 98%
thay way you'll have high settings over 30% throttle and low under 30%
Old Jan 26, 2003 | 01:12 AM
BlackRx7's Avatar
well **** I hate searching and reading like 20 posts!!! this was much faster than that would have been, anyway lets let this thread die.....man that sux!!!
Old Jan 26, 2003 | 01:24 AM
Jimmy325i's Avatar
No longer cares
set your low at like 10% and your high at 99% and then you'll have a smooth transition from power off to power on correction.
How are those bushing measurements coming?
Old Jan 26, 2003 | 01:51 AM
BlackRx7's Avatar
I'm kinda worried Scott hasn't got my money order yet I and I sent it on wednsday, internation pritority mail, I hope it comes in on monday if not I'm going to bitch at my post office!!!!!
Old Jan 26, 2003 | 02:08 AM
bl|nk's Avatar
Fok mi
so how about on a s5 throttle position. i searched too and it seemed like it ranged like 40 / 80 or something.
Old Jan 26, 2003 | 02:29 AM
Jimmy325i's Avatar
No longer cares
Sucky about the money order. Paypal is a blessing for that exact reason. Real time transaction confirmation.
As for the S5 I haven't ever played with one. You'd want to set it up so that your high and low points accurately adjust fuel delivery where the motor needs it, and the range in between extrapolates the correction so that it runs smooth across the variation.
Old Jan 26, 2003 | 10:20 AM
SaabGuy's Avatar
I rigged a full range tps under the dash for my safc to read off of.
Old Jan 26, 2003 | 11:52 AM
COsborne's Avatar
My Custom Title > Your's
I have an s5 manifold laying around with the dual TPSs. I think I might rig it up today and see how it does. I'll let you know if I do it.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
