How to run belt, help ASAP
Old Jan 22, 2003 | 05:26 PM
Domestic513's Avatar
I have a K4 300 belt. Now I wanted to put it on. But I got looking, when facing the car. Does the belt go on the right or left side of the water pump?
Old Jan 22, 2003 | 05:29 PM
Mahjik's Avatar
Mr. Links
Arrow
https://www.rx7club.com/forum/showth...light=air+pump
Old Jan 22, 2003 | 05:50 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
The right side.
Old Jan 22, 2003 | 05:53 PM
Alright but there is no way in hell that a 300 4 rib belt is going to fit on it going on the right side of the water pump. I have stock pullies if that matters.
Old Jan 22, 2003 | 06:18 PM
anyone???? PLEASE!!!!!!
Old Jan 22, 2003 | 06:34 PM
RTS3GEN's Avatar
The Man
the belt deflects off of the right side of the water pump pulley, thus spinning it in a counterclockwise rotation. If you do not install it correctly you will cavitate the pump and just make air bubbles in the coolant thus overheating the car. Good luck.
Art
Old Jan 22, 2003 | 06:36 PM
RTS3GEN's Avatar
The Man
And since this is posted in the third gen section, I assume you realize that the stock belts are 6 rib, not 4 this could be your problem, the 4 should fit on the pulleys but it doesn't have the strength to hold up for long.
Art
LunchboxCritter
15
Jan 3, 2016 04:11 PM
sYnth.
Aug 19, 2015 06:27 PM
