boost controller non sequental problem
Old Jan 22, 2003 | 02:41 PM
1.3maxhp's Avatar
Unhappy boost controller non sequental problem
I did the dont be a rikki non sequental setup on my car everything seemed to be working fine... Then I hooked up my profec b and i cant get the damn thing to work. I get 13 psi with it on or off. I am running off the wastegate because I disconected the turbo precontrol. I ran the line from the turbo to the in on my profec b then had the out going to the wastegate. I capped the other end of my wastegate. what did I do wrong? Is there anyway to check if my boost controller is broken?
thanks guys
Old Jan 22, 2003 | 04:26 PM
Jedon's Avatar
Slave2TheFD
I need to know the same thing, only Ihave the reverse problem, I only get 5-7psi.
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
