Non Seq noise!
Old Jan 21, 2003 | 08:15 PM
mmonaco's Avatar
Part out my Car
Non Seq noise!
I went real Non Seq and now i am hearing a really loud noise right as i get to about 2 LBSof vacuum. It sounds like a party blower, and i havent gone pass 2 LBS of vacuum. Its kinda feels like its wont hold boost. Im waiting on a haltech so i can start boosting it! Has anyone had this problem before? Thanks
Marc
Old Jan 21, 2003 | 08:21 PM
mmonaco's Avatar
Part out my Car
I check the shaft play and there was very little in them! So i wouldnt think they are going, im thinking its one of the block off plates! Well im hoping its one of the BOP!. TIA
Marc
Old Jan 21, 2003 | 11:49 PM
mmonaco's Avatar
Part out my Car
Could this be the sound of my turbos dieing?
Old Jan 22, 2003 | 02:57 AM
BoostedRex's Avatar
NorCal 7's Co-founder
I know that non-seq setup is supposed to be a hell of a lot louder than seq. Though the sound you're describing doesn't seem right to me. You may be right about the BOP. If it's not sealed right then you could be leaking boost out of there and making a whistling type of sound. Run a thin bead of silicone around them and then re-bolt them. I'm not an expert, but hopefully the silicone idea will help some. And BTW did you mean pulling 2 in of Hg(vacuum) or were you boosting 2 lbs?? Best of luck to you. Laterz.
Zach
Old Jan 22, 2003 | 02:55 PM
Alpha-7's Avatar
why is non seq alot louder than sequential
Old Jan 22, 2003 | 05:02 PM
Marshall's Avatar
Because you remove a door in the wastegate that is closed under part throttle operation.
ls1swap
Jun 3, 2024 03:25 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
