Non-turbo FD?
Old Jan 21, 2003 | 06:42 PM
seamusmurrin17's Avatar
Non-turbo FD?
Okay, probably a stupid question, but I am unable to satisfy my curiosity after searching the archives here.
Has anyone run a non-turbo 13B in a FD? Or is it possible to run a 13B-REW without turbos?
As many others have posted, I am mystified by the lack of longevity (max approx 100K mi), which you has been witnessed here in this forum by likely well-maintaining owners, for 3rd gen motors. Heat seems to be the main culprit.
BTW, I am a 2nd gen owner who ran his 13B to 215K miles and now regrets selling it though it was still going strong.
Thanks,
Seamus
Old Jan 21, 2003 | 06:51 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
You have much to learn young grasshopper about way's of turbo charging and the FD.
Old Jan 21, 2003 | 10:32 PM
Narfle's Avatar
Rx7 Wagon
you could remove the turbos, which would take a weekend of straight working, and remapping your fuel
or you could put a 13b
either way = slow
Old Jan 21, 2003 | 10:38 PM
johnchabin's Avatar
Sequential, non-sequential, or just 'non'...
Old Jan 21, 2003 | 10:42 PM
c00lduke's Avatar
That is just ugly
Old Jan 21, 2003 | 10:49 PM
XLR8's Avatar
Well.........If you went NA and still wanted the power, you would have to go with some BIG porting. This in turn would still result in a shortened life span of your loved rotary(under 100k).....Turbo's create more power and compromise reliability, that's just the way it is...There are things you, as an owner can do, however. Upgrade to a FMIC, Bigger radiator, lower the boost when you don't need the power via boost controller.
Good luck...
Old Jan 21, 2003 | 10:55 PM
dpasseto's Avatar
As long as you're not getting on the boost, you're not using your turbos. It's all motor. It's all in how you treat your car.
Old Jan 22, 2003 | 08:47 AM
Exactly. Who wouldn't want a turbocharged FD?!
Old Jan 22, 2003 | 10:58 AM
flunkysama's Avatar
It would be interesting to see a renesis engine from the new RX-8 in a FD. A little less horsepower, but less weight and no turbo lag.
Old Jan 22, 2003 | 12:22 PM
rynberg's Avatar
hmmm...let's compare a torque peak of 160 ft-lbs at 6000 rpm to the almost negligible turbo lag of the stock twins. It's immediately apparent some posters do not actually own an FD....
As far as only a "little less horsepower" goes, I'm willing to bet the Renesis won't make more than 140 ft-lbs of torque at the wheels at its PEAK, while my close to stock 13B-REW makes over 200 ft-lbs to the wheels from 3000 rpm to 6250 rpm. The only time it's below 140 is under 2000 rpm.
Old Jan 22, 2003 | 12:41 PM
Bridgeported's Avatar
To many people, the word Rotary MEANS Turbo.
They go hand in hand. Kind of like "civic" and "slow" or "impala" and "low rider" or "suv" and "rollover", etc.
Old Jan 22, 2003 | 06:46 PM
Jedon's Avatar
Slave2TheFD
There was a 12a powered FD at sevensock a couple years ago, it ran in Formula Atlantic and was set up with all hand controls so a handicapped guy could drive it. It was LOUD.
Old Jan 22, 2003 | 07:09 PM
xstacy7's Avatar
I love when things work
grasshopper? nevermind I won't say anything...
Old Jan 23, 2003 | 02:48 AM
HeX's Avatar
HeX
01010010011010110
Lightbulb Fastest FD
What about an FD with a 1.5L SOHC 100hp honda engine?! That would rock!!!
-HeX
befarrer
Sep 22, 2015 09:33 AM
FCrx7
22
Apr 30, 2002 02:12 PM
