car is running shitty..
Old Jan 21, 2003 | 06:25 PM
half past twelve's Avatar
I installed a PFC PMS, and shortly after I starting noticing that everytime at startup the car would smoke much more than usual, and transition got much slower. Transition takes till about 5.5k till full boost is restore, where previously it would be restore right away. I decided to check the oil and the oil went down a good amount from the last time I checked. I kept looking under the car for oil dripage and to my suprise nothing. I thought it was the PMS settings were far off, but Wade said they were not. Could my second turbo be going out? Or is it something different..
Old Jan 21, 2003 | 06:28 PM
Bucrx7's Avatar
Best thing to do is run just the stock ecu and see if you are still getting the same issues.
Old Jan 22, 2003 | 12:25 AM
Could the car be running excessively rich? Would this cause the slow spool up of the secondary turbo? I noticed that when I let the car idle not much smoke is coming out, but I can see where some liquid is being sprayed outa the exhaust. I blipped the throttle a little and the I get some puffs of smoke. I will try taking the PMS off tomarrow...Any suggestions 'till then?
Old Jan 22, 2003 | 08:33 AM
Doesn't it have to be tuned..? By a professional? Maybe that has something to do with it.
Marty RE
Aug 29, 2015 07:51 AM
smikels
Aug 18, 2015 01:26 PM
ashleymiche
Aug 14, 2015 12:59 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
