Power FC Apex'i Boost Control Kit Questions
Old Jan 21, 2003 | 02:01 PM
capt. bill1's Avatar
I am I correct in assuming that I can still use my Profec B to control boost even with the Apex'i boost control kit installed? And does any one know who has these kits in stock at this time?
Thanks, Bill
Old Jan 21, 2003 | 04:53 PM
twokrx7's Avatar
Need more sleep
Yes you can still use your boost controller.
Contact Ray at SR Motorsports for the kit.
If you do not plan to use the Apexi kit to control boost then consider buying a GM 3bar map sensor and harness for about $60-70. PM me if you cannot find the purchase and setup info on the GM 3bar, I found it on the Forum using the search feature.
Old Jan 21, 2003 | 07:02 PM
Thanks a lot twokrx7.
I like the Apex'i kit because you use the stock map sensor to read ambient air pressure so the PFC can correct for it. But I will let you know if I need the GM info.
cristoDathird
28
May 30, 2019 08:47 PM
