Best Lines For WG.
Old Jan 20, 2003 | 10:30 PM
Marcel Burkett's Avatar
Question Best Lines For WG.
What do you guys concider to be the best type of signal lines to use for the wastegate/s ? silicone hose , steel braided hose or other ? , taking into account the extreme temps. and the close proximity to ultra hot parts (radiation and convection) near the exhaust system.
Old Jan 21, 2003 | 07:20 AM
1FastT2's Avatar
Im persoanlly using silicone lines that are holding up quite well. I had thought for sure they it would be a prolbem because of the heat and them being so close to the DP, but no prolbems so far.
Old Jan 21, 2003 | 06:08 PM
Thanks , anyone else?.
Old Jan 22, 2003 | 10:18 AM
eViLRotor's Avatar
Brother of the Rotary
Silicone. Some braided would be nice though.
Old Jan 22, 2003 | 01:51 PM
Wargasm's Avatar
Weird Cat Man
I have silicone in there now which seems to be doing OK after about 1 year of driving. I'm considering running small diameter copper tubing though... no heat problems there.. haha.
Brian
Old Jan 22, 2003 | 02:29 PM
setzep's Avatar
I'm with orgasm err... wargasm on this one. Hard line all the way. It will give you piece of mind knowing that sucker won't pop off or melt through.
Old Jan 22, 2003 | 02:49 PM
suganuma's Avatar
no
tried routing mine away from the turbine housing, but the line found a way to find enough slack and get hot enough to crack allowing the wastegate to not open all the way and the engine boost to 20+ psi on pump gas....new motor time
this was with silicone line
i am not sure what i am going to use when i put everything back together....maybe some creative heat shielding as i dont really want to put anything directly over the lines so they are still inspectable...
i would be very interested in any ideas and/or current materials used right now.....and pictures would be a great bonus...
-Nic
Old Jan 22, 2003 | 05:15 PM
Wargasm's Avatar
Weird Cat Man
My vote is copper tubing like you'd use on a small sink or something. Maybe 1/4 inch or whatever. It's cheap and easy to work with and you can bend it into whatever shape you need to clear various parts. It will never break, melt, or crack!
The critical areas to keep copper are the parts that go over the turbo/downpipe areas...
I think I'll do a flare fitting connection to the wastegate assuming I can find the right parts to make everything match up. On the boost controller end, I'll just use some short bits of silicone hose.
Brian
Old Jan 24, 2003 | 04:47 PM
I am thinking of using steel braided lines around the turbine area then go back to silicone hose at the boost controller , which is located on the other side of the car, what ya think?.
Old Jan 24, 2003 | 11:20 PM
Directfreak's Avatar
I am a Jeeper Now.
How about just putting the hose within some heat shielding, a'la FyreWire?
BLK 93
11
Sep 9, 2015 10:56 AM
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
