Front sway bar end links?
Old Jan 19, 2003 | 07:56 AM
Question Front sway bar end links?
OK, I bought a wrecked 93 touring to start out (the only way I could afford to do the mods I wanted) and the sway bar/radiator mounts were bent along with the end links. I ordered Suspention Tech front/rear set and was assured from Alamo Motorsports that this would include the links and new polly bushings...most of you probably know I didn't get the links and bushings. So where do I get them? Please help, I don't want stock ones on a bar twice the size as stock.
BTW: My search only found the same question asked in August but had no response...
Old Jan 19, 2003 | 04:15 PM
artowar2's Avatar
Mazdatrix has adjustable heim-jointed end links, so that you can set the bar with zero preload. I think they're for the stock swaybar, so you should check to see if they will work with your bar.
They also have OEM and aftermarket swaybar mounts.
Old Jan 20, 2003 | 09:51 AM
FDjunkie's Avatar
Here's a link for a DIY heim end link.
http://www.scuderiaciriani.com/rx7/a...end_links.html
matty
Jan 18, 2020 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
need RX7
11
Aug 19, 2015 08:27 AM
