I need help?????? (driveability problem)
Old Jan 18, 2003 | 09:46 PM
I need help??????
I was driving to work, and soon as I hit the on-ramp my car started driving very poorly. I thought it to be possibly a blocked fuel filter so I replaced it. Then I noticed my catallytic converter that I just had put on glowing chery red. Panic sets in!!!!
Old Jan 18, 2003 | 10:18 PM
is the air pump working/hooked up?
Old Jan 18, 2003 | 10:25 PM
the air pump is spinning all seems to be in order
Old Jan 18, 2003 | 10:35 PM
slight possabillity its a combo of you runnin too rich, reallyy cheap *** cat, or its not really new at all
Old Jan 18, 2003 | 10:49 PM
wwilliam54's Avatar
it WILL run
clogged cat?
Old Jan 18, 2003 | 10:51 PM
what do you suggest my first move should be
Old Jan 18, 2003 | 10:55 PM
i hope that i don't annoy anyone, i have only had the car for a few months and i have never worked on a rotary before. it's different from any car i have ever worked on
Old Jan 18, 2003 | 11:00 PM
the only thing I can think of is clogged cat or NO air gettin to it from the air pump. give it a day or so, and im sure someone else will chime in on the subject
Old Jan 19, 2003 | 04:43 AM
bobbitt's Avatar
Search 'Glowing red' on this forum...ya might hit on something substantial. I would say it's clogged up, but apparently it's new? Are you backfiring? Ya know some people here think the glow is cool, it's like natural ground effects.
Old Jan 19, 2003 | 03:18 PM
i like ground affects just as much as the next guy, i just dont like the thought of bursting into a speeding ball of flames
Old Jan 19, 2003 | 03:27 PM
bcty's Avatar
Boost This!
just go RB exhaust system and youll love it.. seems like a good time to upgrade.. but im putting my money on the clogged cat
Old Jan 19, 2003 | 03:44 PM
i live in washington state and i have to get emissions tested every other year, if this system will pass the test i would like to look into it
Old Jan 19, 2003 | 08:28 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Do you have a visual inspection in your state?
If not then go for the Mazdatrix "grey-area" exhaust set-up. It uses the RacingBeat header, but with a hi-flo cat instead of the pre-silencer.
http://www.mazdatrix.com/e-gray.htm
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
