rear end clunking
Old Jan 18, 2003 | 06:35 AM
OzFeTt's Avatar
rear end clunking
Hi guys,
I've just bought an fd and I'm getting some pretty bad clunking noises from the rear end, mainly on tight, low speed corners.
I pulled the rear end out and it seems that the tailshaft has been knocking on the handbrake cable mount and a couple of other places on the transmission tunnel. The PPF looks fine (its painted yellow,, does that indicate its a mazdaspeed one?? ) and the diff mounts looked ok too but seemed a bit flexible so I tryed to stiffen them up with some washers. This has helped but the clunking is still there.
The diff is apparently a cusco one and is very tight, so I think its twisting around tight corners and bashing the tailshaft into the tunnel.
Has anyone else had this problem? What can I do about it?
Thanks,
Rob.
Old Jan 18, 2003 | 12:56 PM
Rx7@Rocketship.com's Avatar
You have to check the spherical bearings that are found at several areas of the rear suspension arms.
Jack the car up and grab the wheel at 9 and 3 oclock and try to move it back and forth on the horizontal plane. You will probably find that the "bushing"/bearings are actually worn and loose. It only takes a minute amount of slack at the bearing to have that annoying clunkiness.
Cheers,
David
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
