New Discovery with My R1
Old Jan 17, 2003 | 11:42 AM
HDP's Avatar
HDP
A Fistfull of Dollars!
Well, I discovered yet another issue this past Sunday afternoon. I started the car while I had the hood up and the driver's door open. After it warmed to normal operating temp, I shut the hood and the RPM dropped way down (nearly stalled). I then got in the car and shut the door and it did it again. Could this be a grounding problem? I did a search on it and nothing was mentioned about a drop in RPM in situations like this. Can someone give me a little insite on grounds and the grounding locations?
Old Jan 17, 2003 | 01:22 PM
JONSKI's Avatar
5yr member, joined 2001
Weird, it sounds almost like an oversensative knock sensor. I honesty don't know, though.
Old Jan 17, 2003 | 01:25 PM
Engberg's Avatar
does sound like the knock sensor, try tapping on the block with a hammer (lightly) to see if it happens then too
Old Jan 17, 2003 | 02:45 PM
Tim Benton's Avatar
FD title holder since 94
Don,
That is one weird car...I've never heard of that either. So does it level back out after the door is shut?
Tim
Old Jan 17, 2003 | 02:49 PM
HDP's Avatar
HDP
Where on the block? I don't want to stick my hand in some place and get it burned.
Old Jan 17, 2003 | 02:54 PM
HDP's Avatar
HDP
Originally posted by Tim Benton
Don,
Tim
Yep. I can shut the doors, hood and hatch and the RPM will drop but then jump right back up to what it was(can't say normal cause it's still about 1200). Sometimes, it doesn't do it. I would say it does it about 80% of the time.
Old Jan 17, 2003 | 03:03 PM
1stand3rd's Avatar
Here's another weird one (albeit unrelated). Power your windows up or down while transitioning between the 1st and 2nd turbo. The window will hesitate right at the transition.
Old Jan 17, 2003 | 03:06 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
No thanks. I'll keep my hands on the wheel.
Old Jan 17, 2003 | 04:29 PM
Engberg's Avatar
I think the sensor is in the front of the engine, but it should pick up at rap with a hammer from any place on the block. Find a convienient place that you can tap on it...it is set to pick up knock when not under boost so it should be semi sensitive at idle. Basically the sensor listens to the engine noices for a peak bang or knock and then retards timing so slaming doors and tapping on the block can trick it into thinking it's knock.
Old Jan 17, 2003 | 04:34 PM
striker's Avatar
i believe this is due to the stock fuel pump going into a higher output mode.
Old Jan 17, 2003 | 04:41 PM
shawnk's Avatar
Perpetual Rebuilder
I am at work and dont remember exactly but I thought I saw in the manual that the fuel pump switched from low to high around 2000 rpms (or something lower than I expected). I will look it up if someone else already hasnt verified this when I get home...
Shawn
www.3rdgenrx7.com
Old Jan 17, 2003 | 07:12 PM
HDP's Avatar
HDP
Ok, I just drove the car and tried to make it do it again, and it wouldn't! I think there are gremlins lurking about!!!
Old Jan 17, 2003 | 09:28 PM
CantGoStraight's Avatar
What's your point ?
Couldn't have anything to do with the factory alarm system and load on the electrical circuict ?????? Just a guess as electrical loads play a part on idle.
Old Jan 17, 2003 | 09:39 PM
puma's Avatar
canadian monster
tap on the engine loop. The loop on the UIM were you use the chain to lift the engine.
you will see if it is the knock sensor. there is a procedure to test it, i did it once, check the manual for it, i believe you need to check the voltage somewhere in the diagnosis box
Old Jan 18, 2003 | 01:53 AM
Air-Rex's Avatar
Yea gotta be the knock sensor.
Old Jan 18, 2003 | 03:03 AM
striker's Avatar
wow, 2000rpm???? thats really damn low, why the hell would they design it like that?? why not just have it in high all the time?
Old Jan 18, 2003 | 03:10 AM
Red-Rx7's Avatar
Administrative Me
Many people do convert their fuel pump to run in "high" mode.
Mike
Old Jan 18, 2003 | 08:26 AM
Rated R1's Avatar
Oji San
Here is a pic of the knock sensor:
Old Jan 18, 2003 | 05:36 PM
streetraceseven's Avatar
knock sensor is way off base my car did the same bad grounds. loose grounds. mine were loose behind the Bumper. took me a while to find the prob but i cleaned the connectors and tightned them down now no problems.
Old Jan 18, 2003 | 05:38 PM
even the weldon race pumps have a manual high low swith on them... why dont we make our cars idle at 2000 rpm throttle response and boost will come in quicker..... the reason is longevity.
Old Jan 19, 2003 | 03:00 AM
HDP's Avatar
HDP
Can you give me a little insite on all the grounding locations? Also, did you replace all of them or add any additional ones? Thanks.
Old Jan 19, 2003 | 11:59 AM
Tim Benton's Avatar
Don, some are easy to see....one on the firewall to the Upper intake manifold (easy to get to on the passenger side of car)....add one from the negative terminal to the frame rail....underneath the car, hole where you change the sprak plugs, crud gets built up there from oil changes....various grounds attached to the exhaust piping....check the ECU ground is tight (its behind the passenger kick panel (right foot side).
Tim
HotWheel
115
Mar 26, 2003 08:40 PM
