is it badf to drive a car with "one blown rotor"?
Old Jan 16, 2003 | 08:09 PM
thorin's Avatar
i mean, will the apex seals be chewing up the housing with every revolution?
IE... if i buy a car with said problem, will i be able to drive it home , or will i have to have it towed?
Old Jan 16, 2003 | 08:11 PM
Winnipeg85GSL's Avatar
You'd want to get it towed.
Old Jan 16, 2003 | 08:12 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
If you have one taht is blown , chances it being able to be started without aid of ATF, is almost NONE! Let alone driving it, once the rotor housings are chewed up, then its over, no compression! No running motor...
Old Jan 17, 2003 | 03:51 AM
nimrodTT's Avatar
all aboard!
I had one motor start up easier right after the rear rotor went than right before it did. It depends on if the good rotor has good compression and what damage the one apex did to the housing and other seals.
The last motor I killed had to limp home about 20 miles, topped out around 50mph, took a looong time to get there, and would sputter and jerk if you gave it more than about a quarter throttle while cruising. So unless the car is very close, I wouldn't plan on driving it home with one rotor down.
Old Jan 17, 2003 | 04:04 AM
djmickyg's Avatar
ive seen the after effects of a housing and rotor after being driven on. and it wasnt a pretty site..
but when the apex seal broke im sure it has done enuf damage to make the insides unusable.
if its a close drive i say atempt it otherwise its easy to get it to towed.
are u planing on rebuilding it??
Old Jan 17, 2003 | 05:45 AM
gamble302's Avatar
roadkill hats rock
i had to drive my old car home about 45 miles at 55mph(topped out) because i had to get the thing home. i already knew the internals were scrapped so i went for it. it smoked like the batmobile or somethin. it was badddddddd
that car never let me down, not even on one rotor
id say if you dotn plan on usin that motor, go for it. if you plan on using any internals of that motor get it towed. also if you arent feelin lucky i wouldnt try it either
Old Jan 17, 2003 | 06:08 AM
RotorMotorDriver's Avatar
Seven Is Coming
Yes, its bad.
~T.J.
Old Jan 17, 2003 | 06:13 AM
85RX7GS's Avatar
I'd say that if you wanted to rebuild the engine, definitely DON'T drive it home.
Old Jan 17, 2003 | 08:44 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Originally posted by RotorMotorDriver
Yes, its bad.
~T.J.
Old Jan 17, 2003 | 09:36 AM
faye x7's Avatar
brilliantly stupid
Hey..how about your break one of your legs and walk about 5 miles and see how it feels.
You're engine won't like it...so tow it or if you really want a work out...maybe you can push it! ;D
Old Jan 17, 2003 | 10:11 AM
Turbo12A's Avatar
Originally posted by error402
LOL Funny Shiznit.... Nice..
Old Jan 17, 2003 | 10:19 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
this is how it will look afterwords:
btw: this 13B was completely screwed up. No apex left on the rear rotor, front had some compression, but housing was too far gone aswell
Old Jan 17, 2003 | 10:49 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Very badf, indeedf.
Man, that is one ugly housing!
Old Jan 17, 2003 | 10:07 PM
djmickyg's Avatar
and the rotor
Old Jan 17, 2003 | 10:15 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
it'll sound like a lawnmower, lol
Old Jan 17, 2003 | 10:16 PM
i wonder what a single rotary engine with a T-78 would make for power. Maybe using a larger housing and rotor. That would be sweet. The torque would suck though.
Old Jan 17, 2003 | 10:25 PM
Keaponlaffen's Avatar
They have single-rotor engines for lawnmower tractors.... or so I've heard...
I think that'd be awesome to put in a go-kart
Jeff
Old Jan 18, 2003 | 12:01 AM
HEAVY METAL THUNDER
Jeff
They make those... In Germany there's a Go-Kart that's rotary powered... Can't remember the link though.
BTW my rotor was worse.... Don't have a close up pic, but this is the engine in parts:
Old Jan 18, 2003 | 12:15 AM
680RWHP12A's Avatar
yes you can drive with a blown motor!! usally once it blows the damage is done so it dosnt matter!! i know a guy (super broke) that has been driving his 79 rx7 with a blown motor for over 1 year!!!,,,running on 1 rotor of course!!he even disconnected the rear rotots sparkplugs so the car would stop backfiring!! hey, it works!!i would say the only bad thing is he dosnt get anywhere very fast!!!
Old Jan 18, 2003 | 04:03 PM
mazdaspeedrex's Avatar
DIRTY RX
I've lost compression on two of the three chambers on the rear rotor of my 12a and the only thing I really notice is the noise when open the throttle up. The acceleration is not quite as good but there's snow on the ground so I'm not pushing it anyways. I'll keep running it until I get my other motor rebuilt.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
torky007
Aug 17, 2015 05:14 PM
