going single turbo
Old Jan 16, 2003 | 12:16 AM
going single turbo
ok heres the problem i hace a turbo b16a integra with the t3 t4 and that had full boost by like 4000rpm
now i have my 3rd gen and want to go single looking for some high hp # like 400 or so on the street and high 500 on the track with race gas and still be a resonable spooling on the street like 3500 to 4000rpm what kit should i go with and what fuel requirements do i need any help and insite would be appreciated
94 red rx
3inch downpipe, midpipe and 3.5 greddy power extreme exhaust
power fc and controller
blitz blowoff valve
big greddy stock mount
link to other info and pics
http://www.northernanimation.com/na/eric1.html
Old Jan 16, 2003 | 01:08 PM
Bridgeported's Avatar
It's hard to say what kit you should go with. Generally, any of the "big popular" single turbos can allow you get over 400 rwhp on a streetported 13B. Turbochargers such as the T66, T78, GT35/40, T51 Kai, T04E/R/S, T61, KKK Stage 2, TD06, etc. With a large turbo such as the ones above, you can acheive 400 rwhp by running about 13-20 psi depending on which turbo and the tuning of the engine. You should be able to reach full boost by about 3200-4200 rpm depending on which turbo and how much boost you are running.
For a fuel pump you can add a Walbro 255 lph pump. Other options are to add in a second stock pump which will give you even more flow but requires custom work to make it fit and additional lines and fittings. The bosch pump is a popular choice but is usually not necessary unless going for really high power levels.
For injectors 850cc primary / 1200cc secondary would be a nice setup. You can get away with stock 550cc primary / 1600cc secondary even sometimes if tuned good. 1000cc/1000cc is another option. I'd say if you have about 4000-4300cc total you should be fine.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
