Help Non Seq Turbo Question Almost Done!!!!
Old Jan 14, 2003 | 12:30 AM
apeiron
Okay....
http://www.dontbearikki.com/id49.htm
that is the site I used to do the non seq conversion...
My problem is, I have almost everything finished but I only have 4 lines plugged.There should be 5 total... There are only two lines I have left that run from the LIM "one of them has to be it." One runs to the Y pipe, the other runs to im not sure what it is... but it has a wire hooked up to it... its located between the CCV and the LIM .... what is this??? do I need to plug it, its about 2 inches of hose to this thing, the one to the Y pipe is about 9 inches to a foot long. ( the hose that is)
Old Jan 14, 2003 | 04:25 PM
cewrx7r1's Avatar
Eye In The Sky
If you look at the control hose diagram in the manual you should be able to figure it out. If you do not have a manual, get one.
The only LIM line that you should have left is the one for the EGR valve. If your EGR valve is removed, then no LIM lines are used.
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
