The demons in my RX-7 have been banished!!!
Old Jan 13, 2003 | 08:42 PM
ArchangelX's Avatar
Talking The demons in my RX-7 have been banished!!!
Welps...all of my demons in my RX-7 suspension, and body are solved.
I had a loose camber bolt in the front that was making this awful "clunking" sound everytime the weight shifted in the car. I thought it was a CV joint or something horrible. It turns out it was just loose, the serviceman tightened it, and did my alignment.
I've also finished my sound-deadening for the door panels. I used an asphalt based spray on my passenger door, and then chose to do the driver's side with a rubber based spray.
BOTH of them stink like crap...I've been airing my car out since I finished them. I also took the time to tighten all of my hood panels, door panels, trunk panels, and every other little nut and bolt aI could find.
Since I've finally got the suspension all done up, along with the braking, and that awful clunk has been solved, I took her for a little "test" drive. I've been kinda reserved and haven't even really tested the handling limits due to the problems.
Now...coming home...OMFG...this thing handles and stops like a go-kart!!! It's so amazing what a little alignment and camber adjustment can do!!
I've got so much more confidence..no clunking sound..just solid riding. It sounds just as clean as my Celi...not the almost 10 year old car it actually is.
Awesome!!!
Old Jan 13, 2003 | 09:56 PM
JONSKI's Avatar
5yr member, joined 2001
Congrats!
Old Jan 14, 2003 | 12:09 AM
ArchangelX's Avatar
Thanks! For the congrats..and the reply.
Old Jan 14, 2003 | 07:10 AM
HeX's Avatar
HeX
01010010011010110
Sweeeeeet! BTW, why did you "sound-deaden" the car? What exactly is this "asphalt" spray and did it work? Does it add alot of weight to the car?
-HeX
Old Jan 14, 2003 | 09:02 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
-HeX
Yeah, I'd like some more info also.
Old Jan 14, 2003 | 09:05 AM
Rated R1's Avatar
Oji San
You thought you had a bad CV joint in the front of your car?
Old Jan 14, 2003 | 09:08 AM
jeff48's Avatar
Rotorally Challenged
As far as asphalt type sound deadening goes, it weighs a ton. There are countless threads here and other places asking the best ways to remove OEM and aftermarket sound proofing, undercoating and insulation.
Old Jan 14, 2003 | 09:48 AM
blackscorpio's Avatar
#1 F0RUM TROLL
Get it str8 there are no demons in the car, just tiny little gremlins.
Old Jan 14, 2003 | 09:28 PM
ArchangelX's Avatar
Welps..My car sounded like it had a couple Balrogs from LotR in it.
I sound proofed the car, because I wanted a little bit more of a luxurious ride....the car is already the shiznit, but it's a little on the rough side when you're out cruising the town. My wife likes to ride (and soon drive) in it, so I want her to feel comfortable, and not like we're riding a skateboard. So it's an easy trade-off for me. I'll just add more HP to offset the minor weight gain. I'm not out to do 10's so it doesn't matter to me that much.
And I agree on NOT using the asphalt spray...I posted a topic asking if it would be a good idea or not, and I didn't get any help, so I found out for myself that it stinks, takes forever to dry, and can add a wee bit of weight to your car depending on how much you use. I was going to wait till I got an answer..but after the second day, I said F'k it, and did it anyways.
I didn't use ALOT..just enough to take the "ting" outta the doors.
I recommend you use the rubber spray coating from 3M, that stuff was MUCH better, but still stank like azz.
As for weight...I'm not worried about it. I weighed both cans and it came up to like about 6 lbs with the can. It's not THAT much weight. I think you guys are kinda getting carried away. Unless you're doing some serious competitive racing, that little bit isn't going to help much, and it'll make your car a helluva lot louder.
Hell..if I want to make up the difference, I'll just go on a diet or something.
And yes..I had no idea what the hell a CV joint was until I looked it up. I'm still a newbie when it comes to certain things in cars...but I'm learning as I go.
It does help to be mechanically inclined with these cars.
Old Jan 14, 2003 | 11:04 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
so what did you set your camber too?
Old Jan 14, 2003 | 11:12 PM
ArchangelX's Avatar
Ah..er..I'll have to take a look..lol. I asked him to give me safe settings for the current weather as I'm about to drive down to Eugene, OR to get the engine ripped out...so I didn't want to get too technical.
Lemme scan a copy and I'll post it...too much to write.
I'm not too worried about getting it ready for the track, just yet.
Old Jan 14, 2003 | 11:54 PM
ArchangelX's Avatar
Here's the scan....any suggestions? I'm kinda new to camber adjustments, although I understand how it all works, I don't really know the proper settings for improved handling.
And the High Rez for those of you that want to actually be able to read it...without a magnifying glass.
http://www.imagestation.com/picture/...9.jpg.orig.jpg
(Just copy and paste the link) Suggestions?
Old Jan 15, 2003 | 02:17 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
the high res image link is broken, but thanks for posting it though :-)
Old Jan 15, 2003 | 01:21 PM
ArchangelX's Avatar
Er...no problem...Anyone know what great settings for camber are? I know we're kinda getting into suspension now..but I can't exactly move the post.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Duc852
Sep 22, 2015 03:49 AM
