NS with Profec B???
Old Jan 13, 2003 | 11:56 AM
scottie's Avatar
NS with Profec B???
Hey guys. I am really considering going non-sequential soon. I have a Profec B boost controller on the car now. I was wondering what I have to change if anything for it to work on NS. If anyone has this setup please inform me of any changes you made. I want to do this right the first time if I switch. Thanks!
-scott
Old Jan 13, 2003 | 06:28 PM
scottie's Avatar
TTT
Old Jan 13, 2003 | 07:21 PM
pp13bnos's Avatar
Pineapple Racer
Hopefully, you have all the bolt-ons. But it just depends apon if you want to do the full version, or the rikki version. CJ
Old Jan 14, 2003 | 08:27 AM
Hyperite's Avatar
Vagina Junction
If you set it up correctly the first time, you don't need to change anything regarding the profec.
Old Jan 14, 2003 | 08:53 AM
streetraceseven's Avatar
i hear the factory solenoid does a better job and thats what i use.
Old Jan 14, 2003 | 11:11 AM
Hyperite's Avatar
Vagina Junction
The boost is controlled via pills in the vacuum lines.
If your ECU takes readings faster than the profec and adjusts boost accordingly, and has a shorter vacuum path, then the "stock" setup would be better. Fact is, it's not. Stock ECU doesn't have adjustable boost either.
HTH.
24seven_dada
20
Nov 10, 2018 12:03 PM
RexTech
Oct 17, 2001 10:33 AM
