clutch and elec fan ??
Old Aug 10, 2001 | 07:03 PM
gr0undz3r0's Avatar
1) Hey for those running an electric fan in your NA what setup are you using???
2)Check out this clutch flywheel combo and let me know what you think. NOTE: [scroll to the middle to the internet combo section]
http://www.shaneracing.com/sr86clch.html
I am not sure if i should get the NA or the T2 one. My car is a 87gxlna but I am swaping tranny for a t2???
thanx for the help in Adv.
GZ
Old Aug 10, 2001 | 07:16 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Re: clutch and elec fan ??
GZ
1) I'm using a perma-cool. It is NOT adequate- get a different fan.
2) If you are using a TII transmission, you have to use a TII clutch. You will also need a TII flywheel from the same year motor as yours. (and a TII starter, and a TII clutch slave cylinder, and a TII driveshaft, and a TII differential and axle shafts...)
Old Aug 10, 2001 | 07:22 PM
gr0undz3r0's Avatar
Re: Re: clutch and elec fan ??
I will avoid the permcool....
Also I am getting TII start TII clutch Slave cylinder TII driveshaft TII differential TII Axle shafts... but as far as the clutch flywheel combo kit i will assume that if i get the one from the T2 that should be everything right..??
Old Aug 12, 2001 | 02:59 PM
Dak's Avatar
Dak
Information Regurgitator
Which Perma-cool are you using.I have the 16" hand cutter one with the aluminum blades and it has seemed to work fine for me.
Old Aug 12, 2001 | 05:21 PM
HAILERS's Avatar
HAILERS
If it will help I did a *search* on this site and it seems a lot of folk are using Flex-a-lite Black Magic #150 fans. I think they can be found at summitracing.com.
Old Aug 12, 2001 | 07:22 PM
gr0undz3r0's Avatar
thanx for the flexlite tip i am going to look for some info no..
Blastfastrotary
Sep 11, 2015 12:26 AM
risingsunroof82
Sep 9, 2015 08:06 PM
