PFS PMS and manual boost controller?
Old Jan 7, 2003 | 09:45 PM
half past twelve's Avatar
Do I have to remove my old manual boost controller to use the pms? OR can I just set the manual to 15psi and the work with the pms that way?
Old Jan 7, 2003 | 11:17 PM
duboisr's Avatar
that should work. The pms will only go to 15psi I think, so set it at 14 lbs on the third program.
Old Jan 8, 2003 | 06:01 AM
dubulup's Avatar
development
Is that what Garfunkle (sp?) does?
Old Jan 8, 2003 | 09:30 PM
I tried that and all three settings stay at 10psi. I even went to 400 menu set prim setting at 10psi, then secondary at 12psi. Tried the switch again same thing, 10psi. How do I change the boost settings?
Old Jan 9, 2003 | 09:28 AM
TTT
Old Jan 9, 2003 | 09:58 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Ahh... Rikki's not banned!
Ryan do you have a writeup on your website? I'm interested in this too, but couldn't find the answer.
*edit* Forgot to ask... Is this with the Manual vent learn on, or off? Thanks!
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
