What kind of Watertemp gauge are you using
Old Jan 7, 2003 | 02:55 AM
Pumped's Avatar
?? did you have to bore the hole bigger for the new temp sensor ???
cuz I was looking at this mechanical autometer gauge and the sensor was huge..
are there any particular brands that fit with little/ or no drilling,.. mechanical or electronic
Old Jan 7, 2003 | 07:56 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Do you mean putting the new sensor in the origional location? That I don't know, but the install is really easy if you install a T in the coolant line for the throttle body. Seems to be equal accuracy.
Old Jan 7, 2003 | 08:17 AM
Hyperite's Avatar
Vagina Junction
Cyberdyne Digital with a T in the throttle body coolant line. It's a bit laggy in that location....
~Tom
Old Jan 7, 2003 | 08:25 AM
Just my opinion, if you put the sensor any place not in the block, if the water pump fails pumping, or you suffer a partial loss of coolant, that sender location might not be very indicative of true engine temp. Just something to think about.
Old Jan 7, 2003 | 09:02 AM
Jason's Avatar
The one
I use the Defi D-Gauge pictured here
http://66.216.67.51/product.asp?3=529
Works very well.
Jason
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
