Need some quick advice.
Old Jan 6, 2003 | 03:49 PM
Kaotic Dan's Avatar
Ok. I'm having the whole engine wiring harness replaced on my FD, as well as installing the Denso fuel pump. I figure since it will be torn apart I should replace the vacuum lines at the same time. I'm thinking about doing the vaccum line simplification and removing the air pump. What else do you guys reccomend I do while down there. I will be starting next week and I need to order parts now. So any quick advice will be much appreciated. Thanks guys.
Old Jan 6, 2003 | 04:20 PM
SleepR1's Avatar
Why are you replacing your engine's main wiring harness? This is usually replaced during a motor swap? Not sure what you're doing. How about more detail, if you want detailed answers?
Old Jan 6, 2003 | 05:42 PM
Kaotic Dan's Avatar
When the motor was swapped the harness was butchered by some incompetent mechanic, and the harness burned as a result. The whole thing needs to be replaced now. So we are replaceing the harness, dropping in the Denso fuel pump, installing the Trust Airinx intake I just ordered from rx7.com, and replacing all the vacuum hoses with new silicone ones.
The motor is a Stage III Pineapple Racing motor. I have an AEM Engine Management System on a shelf and it will be installed and tuned once the motor is broken in. Do you think there is any need for me to have a boost controller while the motor is bieng broken in? I figure I will just use the AEM once its installed to control boost.
Old Jan 6, 2003 | 06:39 PM
rynberg's Avatar
There is no reason to remove the air pump unless you are running a midpipe. Of course, running a completely open intake like the Airinx will likely result in a dead air pump anyway. In case you don't know, running a stock cat (or even some hi-flow cats) without an air pump will result in a clogged cat.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
